Multi-Gauge, Wire Connections |
72914S |
May 27 2004, 04:19 PM
love this shot Group: Members Posts: 1,290 Joined: 10-July 03 From: Pensacola,Fl. Member No.: 900 Region Association: South East States |
I`m installing a multi gauge in my `72 (the one with the temp gauge) I`m looking for a wiring diagram ? Has anyone else done it? Thanks Barry
Aaron Cox |
May 27 2004, 04:43 PM
i just did it.
was easy, my car is a 73, so all i had to do was extend the sender wire from the console area to the back of the gauge. make a splitter to jump the switched positive and the negative off the gas gauge. |
MXMARK |
May 27 2004, 04:45 PM
Member Group: Members Posts: 205 Joined: 15-February 04 From: Riverside, Ca. the new (951) Member No.: 1,656 |
72914S, I just put a 911 pressure/temp gauge in mine. I also changed the fuel gauge and installed a CHT gauge. What are you using for the temp sender. I just ran a wire from the temp sender that I put in the drain plug to the gauge and then jumped the positive from another gauge and the ground from that other gauge. Really easy. Just make sure your gauge matches your sender. Mark
MXMARK |
May 27 2004, 04:47 PM
Hi Aaron, You are always one step ahead of me.
Mark |
Aaron Cox |
May 27 2004, 04:53 PM
mark, was in your hood last week. almost stopped by on my way to carcraft for wheel studs.... how you doin? my car runs crappy now, linkage got loose etc..... got it close now, think ill have car-craft finish tuning it/rejet it.
wadda ya think? |
MXMARK |
May 27 2004, 05:04 PM
Aaron, They seem to do good work. What size are the carbs? Maybe we can get them close. Mark
Aaron Cox |
May 27 2004, 05:18 PM
44 idf's. the throttle shaft nut came off (vibration i guess-double nutted now) and couldnt seem to get it right since then, been tinkering a little, pulls real hard and all, but drivability blows. Backfiring for no reason (especcialy on decel) and the car seams to puls at the midrange (i think one carb is opening slightly before the other- i have that under control)
lemme know |
lapuwali |
May 27 2004, 05:24 PM
When the throttle shaft nut came off, could you have lost the seal under the throttle arm, that seals the bearing on the end? If so, air is getting past the bearing, creating a big vacuum leak on that one carb. Backfiring and surging are often caused by being too lean, which supports this theory.
lapuwali |
May 27 2004, 05:27 PM
Mark, can you give me details on the "temp sender in the drain plug"? Is this some VW piece, or something you fabricated? I'd like to put an oil temp gauge in my '71, but dunno where to put the sender.
MXMARK |
May 27 2004, 05:29 PM
72914S, Sorry to Hijak this thread, If you need wiring help, we just did ours, PM us.
Mark |
Aaron Cox |
May 27 2004, 05:30 PM
QUOTE(lapuwali @ May 27 2004, 04:27 PM) Mark, can you give me details on the "temp sender in the drain plug"? Is this some VW piece, or something you fabricated? I'd like to put an oil temp gauge in my '71, but dunno where to put the sender. im pretty sure he means the taco plate (thats what mine runs off) |
MXMARK |
May 27 2004, 05:41 PM
Lapuwali, I could not find a taco plate and temp sender holder so I just put a 12x1.5mm VDO sender with a 150c temp range in the drain plug to match with my 911 gauge to 300f same same. Part #323-092 I know it does not respond as fast as the stock sender location but It works well. This will not work for the 914 gauge(Different range). One wire from the sender to the dash. I hope this helps. I would like to get a Taco Plate, etc. Mark
Lo-Fi Version | Time is now: 18th May 2024 - 05:27 PM |
