Boxster motor thoughts, ...again... |
Mueller |
Jan 17 2005, 04:31 PM
I have access to a Tip from a Boxster S, but I don't know how much the owner wants for it.....I'm guessing 10X more than what I want to pay, LOL |
ajracer |
Jan 17 2005, 09:15 PM
Member Group: Members Posts: 204 Joined: 18-April 04 From: Toronto, Canada Member No.: 1,945 |
RICH
Please fin below a Right/Passenger side view of the tranny and clearly shows the "starter" pocket. Thus looking from the photo make me think that I could mount a starter within this pocket area from the engine side; just a thought. Also I understand that the Cast Aluminum Case could be modified and possibly weld in a starter boss for mounting a starter, and if an adapter plate of some kind was used then the start could be mount to adapter plate, just a thought. Any idea to comments Allan |
rick 918-S |
Jan 17 2005, 11:17 PM
Hey nice rack! -Celette Group: Members Posts: 20,427 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Don't work so hard. Use the Boxster starter in it's current location and Boxster flywheel. Make an adapter plate with counter sunk fasteners to attach it to the block. Slide bolts through the adapter plate tword the trans axle side. Use nuts on the transaxle bolts Based on the photo you posted above there is clearly enough material on the belhousing to allow some shortening to get the input shaft back into the pilot bearing. The casting the bolts slide through looks to be 2" long. If the transaxle interferes with the boxster starter trim the bellhousing. Easy..
P.S. I'd bet there may even be a bolt or two that are on the same base circle. (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif) |
Lo-Fi Version | Time is now: 1st May 2024 - 01:32 PM |
