140 rear springs |
140 rear springs |
mrbubblehead |
May 15 2011, 06:15 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
i just swapped my stock springs with a new set of weltmeister 140 springs this weekend. they are mounted on an old set of red koni which maybe wore out. but i gotta say im pretty dissapointed. i thought they would lower the rear end of my car some. but it didnt lower it a bit, it may even be raised a tad. i made sure that they are installed properly, with the coil ends in there little indents.
after a test drive around town i honestly dont think they made much difference over the stock springs. what gives? this week i will be re building my front end. elephant front bushings (to match the rears) 21mm torsion bars, and a 22mm tarret sway bar. i dont have the dough to buy new shocks or inserts yet. but i am planning on going with bilsteins. so my questions are.... do the springs need time to settle? or is this my ride height? is 140 a good spring rate to match my front setup? how the hell do you guys get your cars to sit so low? |
Mike Bellis |
May 15 2011, 06:22 PM
All coil springs settle. I use Bilstein rear shocks with adjustable height settings. I'm running 200# springs. Get the Yellow Bilsteins for the rear and you can adjust too.
tomeric914 |
May 15 2011, 06:24 PM
One Lap of America in a 914! Group: Members Posts: 1,259 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States |
Do your Koni's have adjustable spring perches? If not, then I'm not surprised that yours sits higher now.
There are two ways to lower it; get a set of shocks with adjustable perches (like Bilstein) or some screw adjustable perches for the shocks you have to get it low. |
mrbubblehead |
May 15 2011, 06:29 PM
Do your Koni's have adjustable spring perches? If not, then I'm not surprised that yours sits higher now. There are two ways to lower it; get a set of shocks with adjustable perches (like Bilstein) or some screw adjustable perches for the shocks you have to get it low. do all bilstein rear shocks have adjustable perches? i have never seen add on "screw adjustable perches". do you have a link? how can i tell if my konis have adjustable perches? is it obvious? |
tomeric914 |
May 15 2011, 06:43 PM
how can i tell if my konis have adjustable perches? is it obvious? It's obvious. There will be a series of recessed rings in the shock body spaced every 1/2" or so. Here's a link to a nice setup. Be careful though, if these are early Koni's with the large diameter body, this may not work for you. http://www.rebelracingproducts.com/Suspension/Steering.html (IMG:http://www.914world.com/bbs2/uploads_offsite/www.rebelracingproducts.com-9101-1305507099.1.jpg) |
mrbubblehead |
May 15 2011, 06:45 PM
how can i tell if my konis have adjustable perches? is it obvious? It's obvious. There will be a series of recessed rings in the shock body spaced every 1/2" or so. Let me look for a link. i checked my konis. they are non adjustable. |
tomeric914 |
May 15 2011, 06:54 PM
i checked my konis. they are non adjustable. Ok, see above, I just edited my post. I'll probably get banned for this, but here is nice writeup on the different adjustable setups over on the "other" 914 site http://www.914club.com/bbs2/index.php?showtopic=115393 |
VaccaRabite |
May 15 2011, 07:08 PM
En Garde! Group: Admin Posts: 13,443 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Eric_Shea |
May 15 2011, 07:16 PM
Interesting suspension tune... 21mm torsion bars up front and 140lb springs in the rear. (IMG:style_emoticons/default/huh.gif)
Your old springs were just that... old. |
mrbubblehead |
May 15 2011, 07:51 PM
Interesting suspension tune... 21mm torsion bars up front and 140lb springs in the rear. (IMG:style_emoticons/default/huh.gif) Your old springs were just that... old. yep....this was a recommendation from a fellow 914er. he said he has the same set up in his race car. (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) |
avidfanjpl |
May 16 2011, 01:43 AM
914 Hemophiliac Group: Members Posts: 720 Joined: 6-April 10 From: Bear, Delaware Member No.: 11,566 Region Association: MidAtlantic Region |
I bought front and rear Bilstein sports, and the damn thing lowered 2 inches in the rear with Weltmeister 140's and after dropping the adjusters on the torsions in the front the car is so low with 50's all around that I cannot insert my hand vertically under the car.
My air deflectors underneath scrape even the lowest speed bumps unless I take them at a 45 degree angle, then they only rub a bit. Damned if I know why it went so low, but ALL the components are new on the car. The Rebel front A arm bushings go on this week. Did you change the shocks when you did the springs? J |
mrbubblehead |
May 16 2011, 06:05 AM
sean_v8_914 |
May 16 2011, 10:00 AM
140 IS too soft for 21mm torsions and 22mm bar. good call on teh 180s. that 22mm bar is very stiff. try it at full soft first.
mrbubblehead |
May 16 2011, 04:34 PM
Lo-Fi Version | Time is now: 14th May 2024 - 05:35 PM |
