Oil pressure warning light, got to find a good one |
Randal |
May 16 2011, 10:37 PM
Summit has the Rebco and Longacre ones, which look to be the same. Anyone using them now? Is there something better? I'd like something that is pretty bright, but maybe I just have to add a LCD light to the package..... |
Chris Hamilton |
May 17 2011, 10:19 AM
Senior Member Group: Members Posts: 611 Joined: 7-March 06 From: Berkeley, CA Member No.: 5,687 |
Does your ECU have an input for oil pressure and a general output?
With some ECUs like the haltech you could input oil pressure and then output to a shift light on the dash, or just have the ECU shut the car off. |
stewteral |
May 17 2011, 11:32 AM
Old Member Group: Members Posts: 384 Joined: 4-December 07 From: Camarillo, CA Member No.: 8,424 Region Association: Southern California |
Summit has the Rebco and Longacre ones, which look to be the same. Anyone using them now? Is there something better? I'd like something that is pretty bright, but maybe I just have to add a LCD light to the package..... Hey Randal, For my V8 conversion, I re-designed the dash with all VDO gauges and used the dual-output sender for the oil pressure gauge with the extra trigger for a low-pressure warning light. For the emergency warming, I put a RED LED in the middle of the dash. I only see the LED light come on with the ignition, before firing the engine, but it's a great back-up if I were to miss the O.P. Gauge suddenly dropping. It's been working great for 8 years. Terry |
sww914 |
May 17 2011, 06:47 PM
I've used a trucker's rear running light. You won't miss it. There's about a bazillion cool looking LED lights on ebay now.
Randal |
May 17 2011, 09:31 PM
Does your ECU have an input for oil pressure and a general output? With some ECUs like the haltech you could input oil pressure and then output to a shift light on the dash, or just have the ECU shut the car off. You are probably right Chris and I'll check it out. I'd still have to have a sending unit as such so taking the first step and installing a conventional assembly. I bought a Rebco unit from Summit, but don't know whether the light will be big enough. So heading down to our local trailer supply dealer to pick up an led tail light to mount somewhere I can see it. |
wndsrfr |
May 22 2011, 07:18 PM
Senior Member Group: Members Posts: 1,428 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Summit has the Rebco and Longacre ones, which look to be the same. Anyone using them now? Is there something better? I'd like something that is pretty bright, but maybe I just have to add a LCD light to the package..... I got one of the longacre 1/2" ones from Summit and placed it on the dash near the top and just swapped leads from the stock one....it's plenty bright--the red one in the photo. The yellow one is high EGT--still learning where to put the setpoint on that, but that's another story... Attached image(s) |
Randal |
May 23 2011, 08:56 AM
Summit has the Rebco and Longacre ones, which look to be the same. Anyone using them now? Is there something better? I'd like something that is pretty bright, but maybe I just have to add a LCD light to the package..... I got one of the longacre 1/2" ones from Summit and placed it on the dash near the top and just swapped leads from the stock one....it's plenty bright--the red one in the photo. The yellow one is high EGT--still learning where to put the setpoint on that, but that's another story... I think you've installed the same one I am buying. http://www.aircraftspruce.com/catalog/inpages/1105698.php Whoo...it took some time to sort out which thermocouples to buy, but I think I finally got it right. So is it hard to get a setpoint working? |
wndsrfr |
May 23 2011, 10:15 AM
http://www.aircraftspruce.com/catalog/inpages/1105698.php Whoo...it took some time to sort out which thermocouples to buy, but I think I finally got it right. So is it hard to get a setpoint working? [/quote] I got the t/c's from Sensor Connection--bought the 12 foot leads and am glad I did, the #3 one just reaches the way I have them routed in behind the driver's seat. Setting up the display is pretty intuitive, instructions are good--pay attention to the +/- leads on the t/c's.....the yellow is +. Jake says that the only time the egt is meaningful is at WOT & want it below 1275F or so. It's really hard to focus on it under WOT conditions on the road--you understand. I've found egt's much higher at partial throttle cruising and currently have the alarm set at 1500 to avoid annoyance. Still can't keep my eyes off of the display & am finding cylinder 1 running maybe 1100F at 60mph in 4th and cylinder 4 will be 1400F with 2&3 in between. Considering swapping injectors from 4&1 to see if that's the cause.... Attached image(s) |
Randal |
May 24 2011, 08:28 AM
There are some great LED lights and sending units here: http://www.superbrightleds.com/?gclid=CIiI...CFQtPgwodd36YSg Now just need to wade through all the products to figure out which one would work best. |
stownsen914 |
May 25 2011, 04:25 AM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
I used a medium sized (2" or so) running light from a trailer for my oil light. Bought it at NAPA. I recently added an orange 2" light for the alternator light. I don't worry too much whether my alternator is working, but it can also indicate if the fan has stopped running for some reason since that can fry a motor pretty quickly.
Scott |
Lo-Fi Version | Time is now: 7th May 2024 - 02:38 AM |
