conversion questions..., 911/flat six donors |
RJMII |
May 18 2011, 09:36 PM
Jim McIntosh Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None |
What engine are you running, what year of 911 did it come out of, what parts did you use from the 911?
speed metal army |
May 18 2011, 09:44 PM
Waiting for the rain to stop... Group: Members Posts: 1,068 Joined: 4-September 10 From: PNW Member No.: 12,137 Region Association: Canada |
Yeah!I a comprehensive shopping list would be cool! (IMG:style_emoticons/default/smile.gif)
May 18 2011, 09:53 PM
> What engine are you running?
3.6L > What year of 911 did it come out of? '95 993 > What parts did you use from the 911? The engine, engine harness, FI computer and Tach (IMG:style_emoticons/default/driving.gif) |
jim912928 |
May 18 2011, 10:11 PM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
What Engine am I running: 3.2l with motronic
What year 911: 84 Carrera What parts did I use: complete front end, tach, engine, wiring harness, fuel pump, DME control unit and corresponding relays, rear brakes (to go along with the front end). I also kept the 915 tranny and the 911 axles & CV's just in case I blow up the 901 one of these days. |
jim912928 |
May 18 2011, 10:14 PM
oh...I also kept the shift tower just in case I use the 915.
SLITS |
May 19 2011, 06:57 AM
'77 2.7L 911S CIS
'74 2.4L 911T MFI '82 3.0L 911SC CIS |
dion9146 |
May 19 2011, 07:54 AM
Member Group: Members Posts: 469 Joined: 16-May 04 From: Buckner, KY Member No.: 2,071 Region Association: MidAtlantic Region |
1969 2.0 liter - the first one
1986 3.2 liter -the second one brain, wiring, tach, temp/pressure gauges to put into my 904 gauge cluster SOLD: 911 engine mounts, exhaust, air conditioning, air box |
wobbletop |
May 19 2011, 08:39 AM
Member Group: Members Posts: 382 Joined: 8-December 06 From: Ontario, Canada Member No.: 7,335 Region Association: Canada |
'78 3.0 SC using carbs
rfuerst911sc |
May 19 2011, 09:39 AM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
78SC using carb's but am working my way purchasing parts to install the 3.2 intake manifold and will do SDS ECU for fuel injection. I also went 911 brakes ( calipers/rotors ) on all four corners. Used the SC tach also.
pcar916 |
May 19 2011, 04:31 PM
1. 1995 993 3.6L and the DME it came with
2. '79 Bilstein 911 struts 3. 100mm SC stub axles and course-splined transaxle flanges. Swapped from 108mm turbo stuff 4. 911 oil temp and pressure gauges Swapped out the 911 tach for an Autometer but it worked just fine. |
kfish914 |
May 19 2011, 04:49 PM
Member Group: Members Posts: 161 Joined: 7-May 08 From: Osceola, Indiana Member No.: 9,026 Region Association: Upper MidWest |
2.7L CIS not in car yet > What year of 911 did it come out of? 74 > What parts did you use from the 911? Engine, CIS, wire harness and brain all came with motor Oil and pressure gauge, tach and fuel pump all purchased separately, however all are from a 74 911 |
John |
May 19 2011, 08:06 PM
My street car:
3.2 Engine 1984 911SC front and rear brake calipers (and emergency brake) 915 transmission 911 steering column and ignition switch (early) 911 tach 911 combo gauge modified into one of my triple gauges 911 front struts and hubs 911 front torsion bars (and A-arms) 911 shifter 911 fuel pump (3.2 carrera) 911 fuel filter (3.2 carrera) |
racerbvd |
May 19 2011, 09:00 PM
Advanced Member Group: Members Posts: 2,368 Joined: 3-February 03 From: Sunny FL. Member No.: 226 Region Association: None |
3.0L, win Plug with 46 Webers, ifI tell you any more, I will have to Kill you.. > What year of 911 did it come out of? 78 911SC > What parts did you use from the 911? The engine, Tach, front Susp & complete brakes from 930,, 7&9X16 Fuchs, RSR front oil cooler & RSR Cribie hood mount fog lights (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 15th May 2024 - 09:13 AM |
