RJMII
May 18 2011, 09:36 PM
What engine are you running, what year of 911 did it come out of, what parts did you use from the 911?
speed metal army
May 18 2011, 09:44 PM
Yeah!I a comprehensive shopping list would be cool!
May 18 2011, 09:53 PM
> What engine are you running?3.6L
> What year of 911 did it come out of?'95 993
> What parts did you use from the 911?The engine, engine harness, FI computer and Tach
jim912928
May 18 2011, 10:11 PM
What Engine am I running: 3.2l with motronic
What year 911: 84 Carrera
What parts did I use: complete front end, tach, engine, wiring harness, fuel pump, DME control unit and corresponding relays, rear brakes (to go along with the front end). I also kept the 915 tranny and the 911 axles & CV's just in case I blow up the 901 one of these days.
jim912928
May 18 2011, 10:14 PM
oh...I also kept the shift tower just in case I use the 915.
SLITS
May 19 2011, 06:57 AM
'77 2.7L 911S CIS
'74 2.4L 911T MFI
'82 3.0L 911SC CIS
dion9146
May 19 2011, 07:54 AM
1969 2.0 liter - the first one
1986 3.2 liter -the second one
brain, wiring, tach, temp/pressure gauges to put into my 904 gauge cluster
SOLD: 911 engine mounts, exhaust, air conditioning, air box
wobbletop
May 19 2011, 08:39 AM
'78 3.0 SC using carbs
rfuerst911sc
May 19 2011, 09:39 AM
78SC using carb's but am working my way purchasing parts to install the 3.2 intake manifold and will do SDS ECU for fuel injection. I also went 911 brakes ( calipers/rotors ) on all four corners. Used the SC tach also.
pcar916
May 19 2011, 04:31 PM
1. 1995 993 3.6L and the DME it came with
2. '79 Bilstein 911 struts
3. 100mm SC stub axles and course-splined transaxle flanges. Swapped from 108mm turbo stuff
4. 911 oil temp and pressure gauges Swapped out the 911 tach for an Autometer but it worked just fine.
kfish914
May 19 2011, 04:49 PM
2.7L CIS not in car yet
74
Engine, CIS, wire harness and brain all came with motor
Oil and pressure gauge, tach and fuel pump all purchased separately, however all are from a 74 911
John
May 19 2011, 08:06 PM
My street car:
3.2 Engine 1984
911SC front and rear brake calipers (and emergency brake)
915 transmission
911 steering column and ignition switch (early)
911 tach
911 combo gauge modified into one of my triple gauges
911 front struts and hubs
911 front torsion bars (and A-arms)
911 shifter
911 fuel pump (3.2 carrera)
911 fuel filter (3.2 carrera)
racerbvd
May 19 2011, 09:00 PM
> What engine are you running?3.0L, win Plug with 46 Webers, ifI tell you any more, I will have to Kill you..
Click to view attachment> What year of 911 did it come out of?78 911SC
> What parts did you use from the 911?The engine, Tach, front Susp & complete brakes from 930,, 7&9X16 Fuchs, RSR front oil cooler & RSR Cribie hood mount fog lights
