911 Strut ID and suspension advice, Need to buy parts |
jmill |
May 19 2011, 04:55 PM
I finally have the cash to get this thing off jackstands but I need help. I need to ID the year of the 911 struts for inserts, ball joints, rotors and bearings. They are 3.5" with A calipers. Does that narrow it down enough? I need a bunch of other stuff but I'll start here.
Mr Shea is going to be hearing from me soon for brake bits. Attached thumbnail(s) |
Eric_Shea |
May 19 2011, 05:06 PM
Bilstein's (I think) - Take off the dust cap and show us the point where the insert screws in. That will help narrow it down. They could be late model (SC) Boge's with a green dust cap. (IMG:style_emoticons/default/wink.gif)
jmill |
May 19 2011, 05:32 PM
It was a PITA getting the insert nut off. I don't have the fancy tool.
Eric, I need to get a list together of all the stuff I need from you. For sure I'll need A caliper rebuild kits, pads and bearings from you. Attached thumbnail(s) |
Eric_Shea |
May 19 2011, 06:21 PM
Boge. (IMG:style_emoticons/default/wink.gif)
914Sixer |
May 19 2011, 07:10 PM
That nut is for KYB shocks. Strut should have 911 part number somewhere around where the Bilstien cover ends.
Eric_Shea |
May 19 2011, 07:14 PM
Correct... I'm not seeing a KYB available for a Bilstein strut so it has to be a Boge me thinks (IMG:style_emoticons/default/idea.gif)
Also... you can see the part number listed in that last shot. John... run that part number and see what year(s) comes up. 911.341.042.02? |
bdstone914 |
May 19 2011, 07:52 PM
bdstone914 Group: Members Posts: 4,520 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
PET has nothing for the part number you posted Ron, We need a better photo of the part number to pinpoint the year and model.
wingnut86 |
May 19 2011, 09:34 PM
...boola la boo boola boo... Group: Members Posts: 1,053 Joined: 22-April 10 From: South Carolina Member No.: 11,645 Region Association: South East States |
I have a set of early 911 struts with KYB inserts and they are Boges (67 - 71 me thinks). 3.0's though, not 3.5 A's...
The nurled nut is different for the KYB inserts...still need Hulk Gloves to remove (IMG:style_emoticons/default/mad.gif) Part # 901-341-080-01 also lists 1-0221-32-982-0 That looks like a later 911 Boge setup... |
Eric_Shea |
May 19 2011, 10:21 PM
QUOTE That looks like a later 911 Boge setup... Indeed... with the 3.5 that's a set of later Boges. |
jmill |
May 20 2011, 08:43 PM
jmill |
May 21 2011, 03:21 PM
So for inserts, bearings, rotors and ball joints what the heck do I ask for?
Eric_Shea |
May 21 2011, 03:45 PM
Appears to be close from what I can see...
911 - Model 341 - Front Suspension 042 - Part Designation 02 - Left Side (the other side should be 01) this "should" be an early SC Boge strut... however, there are some issues as 042 is set as a Bilstein but has a much different left and right designation (30 and 31). I still think this is a Boge (black and KYB): Inserts - Boge - Koni - Bilstein. I like the Boge as a very good euro ride that is lost in the Koni vs. Bilstein wars. Cost effective too. It depends on what you plan to do with the car. Bearings - 911 stuff. Pretty common from 65 through ?? Rotors - Same... basic 911 20mm vented rotor 70 through 83 Ball Joints - Late model pin style. |
jmill |
May 21 2011, 08:59 PM
I'm planning on building a street driven track car with a 2.4 6 with 2.2 S p/c's. What's the best choice for inserts?
jmill |
May 21 2011, 09:10 PM
Anybody have any info/experience with these?
Lo-Fi Version | Time is now: 14th May 2024 - 11:26 AM |
