4WheelDrifter |
Having a mid-life crisis @ 35 ![]() ![]() Group: Benefactors Posts: 201 Joined: 15-April 04 From: Bethel, CT Member No.: 1,934 ![]() ![]() |
This is where I think they are on a 2.0:
Cyl head temp sensor on #3 cyl behind it's intake runner. Air temp sensor is between the throttle body and the oil filler, "pointing" to the throttle body with it's connection to the front of the car. Am I right? Just want to make sure. I'm troubleshooting my engine's rich running condition and don't want make false checks. Another question: I have a 2.0 with the 044 CPU and 037 MPS, What head temp sensor should I be using. The PO gave me a spare 012 sensor. The spare 012 reads 1.6k ohms (air temp about 70) but the one in the car reads 3k ohms with the engine cold (car sitting for 2 days, Garage slightly cooler than outside temp). After reading Brad's site, it seems the spare 012 sensor is defective and the one in the car is good. Am I right on this? Thanks! |
mike_the_man |
I like stuff! ![]() ![]() ![]() Group: Members Posts: 1,338 Joined: 11-June 03 From: Regina, Saskatchewan, Canada Member No.: 809 ![]() |
Sounds to me like you're right on the locations. Pictures would be good to be positive, but from the description, it sounds like you're looking at the right sensors. It also sounds to me like the sensor in the car is good, but I can't remember the exact values. What does the CHT sensor read when the engine is hot? The value should drop considerably, can't remember what it should read off the top of my head, but if it's not dropping enough it will cause the car to run rich.
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,338 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
IIRC, about 3K cold is correct. Brads site also has a list of what components go together.
Yes. By your description, you are looking at the right parts. Uh, wait. air temp sensor is on the plenum below the throttle body. Plug has three wires (I think). The AAR is just forward of that location also. |
pbanders |
Senior Member ![]() ![]() ![]() Group: Members Posts: 943 Joined: 11-June 03 From: Phoenix, AZ Member No.: 805 ![]() |
Your description of where the CHT is located is correct. What you think is the air temp sensor is actually the thermoswitch for the CSV. The air temp sensor screws into the top of the air distribution box (plennum).
The '73 2.0 setup has: CHT: 0 280 130 017 (plus a 270 ohm ballast resistor in series) MPS: 0 280 100 037 ECU: 0 280 000 037 The '74 2.0 setup has: CHT: 0 280 130 012 (or a 0 280 130 003, same sensor with a longer lead) MPS: 0 280 100 043 ECU: 0 280 000 043 (or a 044) Your setup is mismatched. Hard to say which way is the best to go. The '73 setup was somewhat of a kludge, I generally recommend changing to the '74 setup. But that means for you, a new MPS. Pricey. At 70 deg. F, the 012 CHT should read closer to 3K ohms. If it reads 1.6 K, it's too low and will be lean on startup and throughout warmup. Brad Anders |
lmcchesney |
Member ![]() ![]() Group: Members Posts: 488 Joined: 24-November 03 From: Ocala, Fl. Member No.: 1,381 Region Association: None ![]() |
Regarding MPS's:
QUOTE All MPS's are basically the same. Some are short nosed some are long nosed, some have different spring rates. I use a Waveteck to calibrate them to my known data which is very similar to BradAnders data. I do have a NOS 043 that I use to check the wavetek everytime before I calibrate a unit. The 037 (73 2.0l) has way different settings than the 049 and 043. The 049 and 043 are pretty much the same except for the WOT settings. You can set up a MPS though and it will spec out perfectly then go for a drive and it runs like shit! These units are old so if you want perfect running car get a new one! I harvest good diaphrams out of MPS's then rebuild them for 2.0l's. The AA rebuilt MPS's I have seen are junk ! Geoff |
morph |
quality parts builder ![]() ![]() ![]() Group: Members Posts: 1,828 Joined: 25-November 03 From: oregon coast Member No.: 1,389 Region Association: Pacific Northwest ![]() |
Brads site?
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
4WheelDrifter |
Brad, the compatability chart on your page says the 037 can work with an 044 CPU or am I reading it wrong?
I'd like to get an 043 MPS, anyone have one for a reasonable price? Are rebuilds any good, I'm hearing mixed things about them. I'll look for the air temp sensor and check it. Thanks for the help guys. (IMG:style_emoticons/default/pray.gif) |
lmcchesney |
Bullett has a parallel post going on presently.
http://www.914world.com/bbs2/index.php?act...=ST&f=2&t=12666 Brad and Geoff answer these and other questions. L. McC |
4WheelDrifter |
Well my 037 MPS tested good with a vac. I'll check the primary and secondary coils next. Then fuel pressure.
Anyone want to trade a good (if the coils read good) 037 MPS for a good 043? |
Lo-Fi Version | Time is now: 8th July 2025 - 01:49 PM |
