Toast |
Not bad for carrying sway bars. ![]() ![]() ![]() ![]() Group: Members Posts: 3,380 Joined: 20-January 04 From: Las Vegas Member No.: 1,580 Region Association: Southwest Region ![]() |
All ready to go to the WCC and what happens!?....
The Master Cylider goes out! (IMG:style_emoticons/default/headbang.gif) *Sigh* So its back under the car we go..... Did I ever mention I have an inherited family curse called "Bad Car Carma"? Luckily, just happen to have a spare cylinder core. Let's hope this thing gets runnin right. (IMG:style_emoticons/default/pray.gif) |
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,300 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
Better at home than anywhere else. Now you'll be fine.
skline |
Born to Drive ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,910 Joined: 26-December 02 From: Costa Mesa, CA Member No.: 17 Region Association: Southern California ![]() |
So whats the status Toast? you guys going to make it up? Or are you calling it quits? You just gotta try harder. If you need parts, I got a bunch of them. No M/C however, but just about everything else.
Toast |
Thanks Scott, it's all covered. Let's see, now for the whole story. Last night was going to install the radio and wash the car. Noticed a large puddle of fluid underneath the front end (IMG:style_emoticons/default/ohmy.gif) . A feel of the fingers and a taste revealed it to be brake fluid. Ah Shit!
So, today, changed the master cylinder. After taking the old one out, found the problem to be the reservoir feed tube bushings to be bad. Ah Shit again. MC was ok. So went ahead and replaced the MC anyway. Tried to bleed the system, but could get no pressure. Ah Shit #3. (IMG:style_emoticons/default/headbang.gif) So, thought the pedal rod might be to long so tore out the pedal board only to find out the pedal rod wasn't even in the MC (IMG:style_emoticons/default/ar15.gif) Ah Shit #4. Ok, finally was able to pry MC far enough away to get pedal rod in. (IMG:style_emoticons/default/smilie_pokal.gif) Now I have pressure and will spend the night trying to bleed the air out, but I don't use brakes anyway (IMG:style_emoticons/default/burnout.gif) , so stay the F__K outta my way - (IMG:style_emoticons/default/laugh.gif) Now, with my luck, I'll hook up the radio and it will probably burn up the wiring harness. (IMG:style_emoticons/default/barf.gif) I'll see you in SJ if I have to tow it with my truck and a rope - Southern Cal style - damnit (ya listening Miles?) |
AZ914 |
914 Dumbass ![]() ![]() ![]() Group: Members Posts: 1,469 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region ![]() |
Toast,
That pretty much sums up every project I undertake on the car. (IMG:style_emoticons/default/headbang.gif) 2 steps forward, 1 step back... |
Toast |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
Yeah, is Miles gonna show up for a surprise appearance......
Geoff (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 30th July 2025 - 11:52 AM |
