Inland Empire: Porsche/VW 914 Engine - Balanced and Blueprinted (Gavil |
914World |
May 22 2011, 11:22 AM
Member #1 Group: Members Posts: 130,681 Joined: 23-December 02 From: World Wide Web Member No.: 1 Region Association: None |
Porsche 914 Longblock Engine ..1800cc .. #2011
Stock Daily Driver .. '69-'74 / 1.7 & 1.8 Models Call 310-430-4913 w/ questions to see.... -------------------------------------------------------------------------------- 1700cc Stock 914 Longblock Engine -------------------------------------------------------------------------------- Daily Driver . Stock Restoration . Applications below ITEM # -------------------------------------------------------------------------------- 2011 SIZE -------------------------------------------------------------------------------- 1700cc BORE -------------------------------------------------------------------------------- 93mm STROKE -------------------------------------------------------------------------------- 66mm CYL HEADS -------------------------------------------------------------------------------- 4-Stud Intake FLYWHEEL -------------------------------------------------------------------------------- 215mm 1973-74 Porsche 914 '1.8' applications... 4-Stud intake cylinder heads. Stock fuel injection. LONGBLOCK ENGINE FEATURES of this Product # ENGINE CASE Porsche O.E.M. Factory Engine Case .. Professionally Selected, Prepped and Remanufactured. Heavy Duty Alloy. Oil galley plugs modified for oil leak prevention. CYLINDER HEADS Porsche Cylinder Heads..(per Table above), Remanufactured. Prepared to run at optimum performance on unleaded gas. 8.5:1 Compression Ratio CAMSHAFT & VALVE TRAIN Porsche O.E.M. Camshaft...Remanufactured hand-selected Remanufactured Rocker Shaft assemblies. Valve Adjuster Screws replaced. Hi Carbon Steel Performance Pushrods. CRANKSHAFT Forged Porsche O.E.M. Crankshaft...Remanufactured CONNECTING RODS Porsche 'O.E.M.' Rods...Remanufactured. Balanced and Matched set. PISTONS & CYLS. New High Tech AAP Performance Alloy Pistons. New Rings, Cylinders and wrist pins. FLYWHEEL Porsche 914 215mm Remanufactured Balanced Flywheel is installed. OIL PUMP New or Remanufactured Heavy Duty Oil Pump. Pumped volume increased 15-20%. GASKETS - BEARINGS - SEALS All New Main, Rod and Cam bearings from German licensed manufacture. New Gaskets and Oil Seals are used throughout.
Lo-Fi Version | Time is now: 17th May 2024 - 08:39 PM |
