Stock Daily Driver .. '69-'74 / 1.7 & 1.8 Models
Call 310-430-4913 w/ questions to see....
1700cc Stock 914 Longblock Engine
Daily Driver . Stock Restoration . Applications below
ITEM #
2011 SIZE
1700cc BORE
93mm STROKE
66mm CYL HEADS
4-Stud Intake FLYWHEEL
215mm
1973-74 Porsche 914 '1.8' applications... 4-Stud intake cylinder heads.
Stock fuel injection.
LONGBLOCK ENGINE FEATURES of this Product #
ENGINE CASE
Porsche O.E.M. Factory Engine Case .. Professionally Selected, Prepped and Remanufactured. Heavy Duty Alloy.
Oil galley plugs modified for oil leak prevention.
CYLINDER HEADS
Porsche Cylinder Heads..(per Table above), Remanufactured. Prepared to run at optimum performance on unleaded gas.
8.5:1 Compression Ratio
CAMSHAFT & VALVE TRAIN
Porsche O.E.M. Camshaft...Remanufactured hand-selected
Remanufactured Rocker Shaft assemblies. Valve Adjuster Screws replaced.
Hi Carbon Steel Performance Pushrods.
CRANKSHAFT
Forged Porsche O.E.M. Crankshaft...Remanufactured
CONNECTING RODS
Porsche 'O.E.M.' Rods...Remanufactured. Balanced and Matched set.
PISTONS & CYLS.
New High Tech AAP Performance Alloy Pistons. New Rings, Cylinders and wrist pins.
FLYWHEEL
Porsche 914 215mm Remanufactured Balanced Flywheel is installed.
OIL PUMP
New or Remanufactured Heavy Duty Oil Pump. Pumped volume increased 15-20%.
GASKETS - BEARINGS - SEALS
All New Main, Rod and Cam bearings from German licensed manufacture. New Gaskets and Oil Seals are used throughout.
- it's NOT ok to contact this poster with services or other commercial interests
