> Where to buy high temp flexible radiator hose?
914_1.8t
post Jun 3 2004, 01:02 PM
I am looking for some high temp hose to use with my conversion. I've seen that quite a few people with water cooled are running these from teh radiator to the engine.
I've tried various places with no luck. I would appreciate it if someone can tell me where I can purchase this from.
Also, What is the recommended diameter to use for the hose.
Thanks.
Mueller
post Jun 3 2004, 01:32 PM
914 Freak!
Renegade sells the hose.
I "think", 1.5 and 1.25 are the sizes they recommend
914_1.8t
post Jun 3 2004, 04:01 PM
QUOTE(Mueller @ Jun 3 2004, 11:32 AM)
Thanks...I'll try them.
Sammy
post Jun 4 2004, 10:00 AM
McMaster Carr sells it too, gates green stripe I think it was.
www.mcmaster.com
John2kx
post Jun 4 2004, 10:51 AM
This is taken from some spare pieces I have left from a recent Renegade kit:
As marked on hose-
"Gates Green Stripe II Heater Hose 1-1/4" MO1170" This one is installed from outlet of radiator to inlet of water pump. Note: this is a I.D. measurement.
"Gates Green Stripe II Heater Hose 1" MO2122" This one is used as a return hose from discharge of block (thermostat housing, fill port etc.) to inlet of radiator. Also used at discharge of water pump to inlet on block (2) ea. Note: this is a I.D. measurement.
Wall thickness of both hoses measure 3/16".
John
Sammy
post Jun 4 2004, 11:32 AM
Yup, that's what I used on my conversion, gates green stripe 1" and 1 1/4" purchased from McMaster Carr.
It turned out to be pretty cheep, and I didn't have to pay shipping because I will-called the order.
- Lo-Fi Version Time is now: 14th April 2026 - 03:06 PM
