WTB: 5 lug cross drilled 914 front rotors. |
tottestad |
May 28 2011, 10:16 AM
Newbie Group: Members Posts: 2 Joined: 29-March 11 From: Orange, California Member No.: 12,873 Region Association: Southern California |
I need a set of front rotors for a 914. I currently have fuchs 16" wheels, so they need to be 5 lug rotors. Also I need a set that will cool better than stock. I have a fun little car with a turbo subaru motor but i cant drive it, as it my current rotors are gold and blue from heat. This car is not a race car, but a hobby that keeps me sober. I jst want to drive with the top off in california, but its currently not safe. Any help or suggestions would be greatly apreciated.
Thanks. |
bdstone914 |
May 28 2011, 10:49 AM
bdstone914 Group: Members Posts: 4,520 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
What thickness rotors do you need? Ive got quite the collection of good rotors.
tottestad |
May 28 2011, 10:54 AM
bdstone914 |
May 28 2011, 10:57 AM
So you are looking for a set of 4 lug solid cross drilled rotors converted to 5 lug? Or You need a 911 front end and you just bolt on those front wheels. Either way I probably have all the parts you need. Ill go look if I have any 4 to 5 lug rotors.
tottestad |
May 28 2011, 11:02 AM
I am open to both options, but I am budget minded.
Thanks so much for your time. So you are looking for a set of 4 lug solid cross drilled rotors converted to 5 lug? Or You need a 911 front end and you just bolt on those front wheels. Either way I probably have all the parts you need. Ill go look if I have any 4 to 5 lug rotors. |
bdstone914 |
May 28 2011, 11:16 AM
is 400+ out of your budget? Thats about the cheapest you can go for a 911 front end on a 914. What are you doing for the rear of the car?
tottestad |
May 28 2011, 11:24 AM
is 400+ out of your budget? Thats about the cheapest you can go for a 911 front end on a 914. What are you doing for the rear of the car? 400 is beyond my budget right now. was looking primarily for just the rotors. That's a great price for the front end. I assume its complte? |
tottestad |
May 28 2011, 11:47 AM
eric9144 |
May 28 2011, 11:58 AM
Advanced Member Group: Members Posts: 2,734 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California |
If you have a fast Suby motor in there, it would be worth the $ and time for the piece of mind that the 911 front end would give you, not to mention it would be a helluva lot safer!
tottestad |
May 28 2011, 12:02 PM
tottestad |
May 28 2011, 12:43 PM
tottestad |
May 28 2011, 01:06 PM
Why does it say "lurker" by my name? (IMG:style_emoticons/default/WTF.gif)
bdstone914 |
May 28 2011, 01:09 PM
Found a set of new rotors that are the ones you want. 4 to 5 lug re drilled, and cross drilled. $100 +sh
As for the 911 suspension, for 400 you would be getting 3" 911 front struts, rotors, core calipers. if you want the a arms and aluminum support it would be extra. I will be available after 6pm today to call you if that works for you. -Bruce And it says lurker by your name because you have no posts yet in the garage. Meaning you are just someone on the board who lurks around. nothing bad. |
tottestad |
May 28 2011, 01:14 PM
Found a set of new rotors that are the ones you want. 4 to 5 lug re drilled, and cross drilled. $100 +sh As for the 911 suspension, for 400 you would be getting 3" 911 front struts, rotors, core calipers. if you want the a arms and aluminum support it would be extra. I will be available after 6pm today to call you if that works for you. -Bruce And it says lurker by your name because you have no posts yet in the garage. Meaning you are just someone on the board who lurks around. nothing bad. Hi Bruce. I sent you a pm with my phone number. I work late tonight. I really want the rotors. Do you have a photo? |
eric9144 |
May 28 2011, 06:12 PM
@Tottestad...If you are having"issues" with the stock brakes being under engineered for the power etc you have going on, then buying stock rotors drilled to 5 lug will do nothing for your situation, in fact it could make it worse as you're likely going to put a heavier wheel tire combo on it.
Really the only option would be to go 911, but on that note, I'd probably pass on a 3" spindle set as the options for future brake upgrades are far fewer with the old spindle's caliper mount spacing. The 3" were the real early 911s, they changed later to 3.5" spacing on the caliper mounts... You need vented rotors up front, the solids just aren't going to give you what you're looking for, IMHO, you'd be wasting your money buying a re drilled set, I'd wait until you could pick up a 911 front end or you will be in the same exact scenario with different wheels on the car. |
ewdysar |
May 29 2011, 01:24 AM
What happens here, stays here. Group: Members Posts: 558 Joined: 29-October 04 From: Altadena, CA Member No.: 3,030 |
(IMG:style_emoticons/default/agree.gif) You will be better off with vented rotors and the cheapest conversion to vented can be the 911 front end. I also agree with the suggestion to go for the 3.5" spacing.
tottestad |
May 29 2011, 02:36 AM
(IMG:style_emoticons/default/agree.gif) You will be better off with vented rotors and the cheapest conversion to vented can be the 911 front end. I also agree with the suggestion to go for the 3.5" spacing. Thank you, and thank you. I think I found a 911 front setup. I realy appreciate your time and opinions. You don't think the 3" setup is enough? |
eric9144 |
May 29 2011, 09:31 AM
The 3" isn't 'bad'...you just have far more caliper options for future upgrades if you get a 3.5" front end...that way you can start with the calipers it came with, then upgrade later on depending on your needs, there are many 3.5" caliper setups--Boxter, mono block, big reds etc...the 3" there's really only S calipers and some brembos, both about the same size and a lot more money to do....
bdstone914 |
May 29 2011, 09:34 AM
S calipers are 3.5" spacing too.
tottestad |
May 29 2011, 09:47 AM
Good morning. Thank you all again. What years are the early 3" 911? Bruce I hope the flight went well.
Lo-Fi Version | Time is now: 15th May 2024 - 11:07 AM |
