What's the Best Adjustable Rear Coil Over Kit, For Bilstein Sports |
jmill |
May 29 2011, 01:16 PM
What's the best one out there for street/track?
brant |
May 29 2011, 01:22 PM
914 Wizard Group: Members Posts: 11,624 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
oops...
racerbvd |
May 29 2011, 03:10 PM
Advanced Member Group: Members Posts: 2,368 Joined: 3-February 03 From: Sunny FL. Member No.: 226 Region Association: None |
I would like to know as well... (IMG:style_emoticons/default/confused24.gif)
Elliot Cannon |
May 29 2011, 04:13 PM
I use Bilsteins with adjustable perches and 160 pound progressive springs. I don't know if they are the best but they seem to work for me OK. Instead of asking, "what is the best"? Maybe you should ask,"in your opinion what is the best". Because that's what you are going to get. (IMG:style_emoticons/default/av-943.gif) Opinions. (IMG:style_emoticons/default/popcorn[1].gif)
Hah! I just realized. This is post number 2000. Wait a minute. I just realized, they ALL say 2000 (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/laugh.gif) |
ewdysar |
May 29 2011, 04:46 PM
What happens here, stays here. Group: Members Posts: 558 Joined: 29-October 04 From: Altadena, CA Member No.: 3,030 |
Just like the title says, what's the best one out there? It depends. The stock coil overs aren't too bad for what they were designed for. You need to define what you're loking for. Lowered ride height? Adjustable perches? Street driving? AX? Big track? They all have different "best" answers. There is no "one size fits all" answer like your question implies. |
jmill |
May 29 2011, 05:30 PM
The original title was vague. I clarified it.
Derek Seymour |
May 29 2011, 06:59 PM
Member Group: Members Posts: 394 Joined: 10-March 09 From: Yucaipa Member No.: 10,151 Region Association: Southern California |
I have a fun setup. Sorry pics are on my PC and I don't have them on an online photo storage site.
The threaded sleeve per usual sits on the metal clip/ring that bands around the lower portion of the shock. On top of the adjustable perch I have the stock perch with a portion of the internal ring cut out to clear the threads. This allows me to run a 180lb progressive Weltmeister spring rather than a Koni or a Von. Is it the best? Probably not. Is it cheap and based around the spring I have always used, yep. |
Michael N |
May 29 2011, 08:40 PM
Certifiable Group: Members Posts: 1,426 Joined: 6-June 04 From: San Jose, Ca Member No.: 2,164 Region Association: Northern California |
I went with the rebel racing adjustables that are good for Koni or Bilsteins.
Rebel Racing I had them set once when alignment and corner balanced and have left them set there ever since then. They have to save weight over the stock units. |
CrashDown |
May 29 2011, 08:46 PM
Fake Carbon Fiber MASTA! Group: Members Posts: 159 Joined: 8-June 09 From: Union City, CA Member No.: 10,453 Region Association: Northern California |
I went with the rebel racing adjustables that are good for Koni or Bilsteins. Rebel Racing I had them set once when alignment and corner balanced and have left them set there ever since then. They have to save weight over the stock units. I've heard alot of good things about the Elephant racing sleeve and sprink kit for the adjustable perch bilstiens...... probably what I'm gonna do sometime in the future. Also a really nice set of RsR adjustable's on ebay all the time. |
jmill |
May 29 2011, 09:08 PM
I went with the rebel racing adjustables that are good for Koni or Bilsteins. Rebel Racing I had them set once when alignment and corner balanced and have left them set there ever since then. They have to save weight over the stock units. I like the Rebel Racing Kit. I even tried calling Clint a few days ago to buy it. His machine was full. (IMG:style_emoticons/default/WTF.gif) |
jim912928 |
May 29 2011, 09:33 PM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
I went with a rebel racing bilstein setup. They are very knowledgeable and set me up with exactly what I needed for my weight and driving style. After installing these units the ride is great!
J P Stein |
May 30 2011, 08:22 AM
Not the "best" I'm afraid but when I did the deed they were "available" back in the day.
It's a Colman set up......and the price was right (including the spring price....60 bucks a pop). These required some rework to make them fit properly. One would hope that nowdays there is a set-up that fits without the mods. BTW, the zip ties broke. I ended up with multiple wraps of safety wire to hold the hats to the springs. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 17th May 2024 - 07:02 PM |
