WTB: 911 front brake setup |
tottestad |
May 30 2011, 05:26 PM
Newbie Group: Members Posts: 2 Joined: 29-March 11 From: Orange, California Member No.: 12,873 Region Association: Southern California |
it seems ive been talked into a 911 front brake setup. What do's and dont's should I be concerned with?
tottestad |
May 30 2011, 05:36 PM
This one im considering.
jaxdream |
May 30 2011, 09:29 PM
Senior Member Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
The pic is of an very early 911 setup ( are they solid or vented rotors ?? ) . You didn't mention the year of 914 you want to convert . If you have wedge pin balljoint front end , you could just get struts , calipers , hubs ,bearings ,rotors to get bigger braking with 5 lug. You don't necessarily need the crossmemeber , a arms , just use your 914 a arms , steering rack , crossmember and tierods. " M " ( 3.0 inch caliper bolt spacing ) struts can usually be had for a little less than later ( 3.5 inch caliper bolt spacing ) and still run vented rotors . Check out some of the classic threads and restoration builds to get an idea of what others have done to convert to 5 lug / bigger brakes. Good luck ...
Jack p.s. Welcome to the World !!!!!! |
tottestad |
May 30 2011, 10:23 PM
My 914 is a 1975. I've recently put a turbo subaru motor in it, and the solid front rotors with bmw calipers are getting way hot. Thank you for the advice. Will the struts in the photo bolt up to my current setup?
jaxdream |
May 31 2011, 07:08 AM
My 914 is a 1975. I've recently put a turbo subaru motor in it, and the solid front rotors with bmw calipers are getting way hot. Thank you for the advice. Will the struts in the photo bolt up to my current setup? No , the setup appears to be pre 69? 911, 70 for sure . Jack |
bdstone914 |
May 31 2011, 07:21 AM
bdstone914 Group: Members Posts: 4,520 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Stay away from those early 911 front suspensions. I will not take them for free.
I should have either a 3 or 3.5 inch later 911 front suspension for you. Give me a call or arrange a time to come out and look at the suspensions I have. Bruce My 914 is a 1975. I've recently put a turbo subaru motor in it, and the solid front rotors with bmw calipers are getting way hot. Thank you for the advice. Will the struts in the photo bolt up to my current setup? No , the setup appears to be pre 69? 911, 70 for sure . Jack |
Lo-Fi Version | Time is now: 14th May 2024 - 08:52 AM |
