`72 VS `74, turn signal switch |
72914S |
Jun 7 2004, 06:27 PM
love this shot Group: Members Posts: 1,290 Joined: 10-July 03 From: Pensacola,Fl. Member No.: 900 Region Association: South East States |
I think I found a problem . When I first started this project the turn signal switch and the wiper switches where both broken off (`72), so I changed them with the ones off my parts car(`74) .Everything seemed ok they plugged right in. The only blinker that works is the left front .I`ve double checked all connections at the lights , lights all work with head lights on , brake lights work but not the turn signals. Did I do it wrong? I recall hearing these switches are not interchangable? Did I mention that every time I try the right turn signal it pops the 8 amp fuse. (IMG:style_emoticons/default/headbang.gif)
lmcchesney |
Jun 7 2004, 06:43 PM
Member Group: Members Posts: 488 Joined: 24-November 03 From: Ocala, Fl. Member No.: 1,381 Region Association: None |
Shorts, shorts and shorts. You need to look for a short in the circuit.
Oh yea, not like your avatar. |
72914S |
Jun 7 2004, 08:44 PM
My real question is are switches for all years the same? (IMG:style_emoticons/default/confused24.gif)
markb |
Jun 7 2004, 09:21 PM
IIRC, the later switches have more connecters than the early ones. You need to be sure it's plugged in right. I just put a later switch in my 72 to add the later style washer switch and the intermittant relay, and it works fine.
72914S |
Jun 8 2004, 06:06 AM
Thanks I`m going to pull it apart tonight and recheck my installation. After all it was six years ago when I did that part!
Lo-Fi Version | Time is now: 22nd May 2024 - 09:32 AM |
