I think I found a problem . When I first started this project the turn signal switch and the wiper switches where both broken off (`72), so I changed them with the ones off my parts car(`74) .Everything seemed ok they plugged right in. The only blinker that works is the left front .I`ve double checked all connections at the lights , lights all work with head lights on , brake lights work but not the turn signals. Did I do it wrong? I recall hearing these switches are not interchangable? Did I mention that every time I try the right turn signal it pops the 8 amp fuse.
