Engine build question, re:crankshaft end play |
76-914 |
Jun 3 2011, 12:15 AM
My endplay is .09 before the spacers and flywheel bolt on. The 3 spacers measure .004. Ultimately leaving me with .05 end play. Is this OK? Seems like a lot.
charliew |
Jun 3 2011, 02:14 PM
Do you mean .005? as in 5 thousandths or .050 as in 50 thousandths? 50 thousandths is probably about 44 thousandths too much.
McMark |
Jun 3 2011, 06:22 PM
I've found that the best way to measure everything is to bolt everything together with 3 spacers and then measure the endplay. Better to install and measure 2 or 3 times, then to add up measurement errors, or make slightly incorrect assumptions.
(IMG:style_emoticons/default/wink.gif) |
76-914 |
Jun 4 2011, 08:22 PM
I've found that the best way to measure everything is to bolt everything together with 3 spacers and then measure the endplay. Better to install and measure 2 or 3 times, then to add up measurement errors, or make slightly incorrect assumptions. (IMG:style_emoticons/default/wink.gif) Thx, that was my guess. I should end up w/ .003 after the shims |
majkos |
Jun 4 2011, 10:13 PM
Senior Member Group: Members Posts: 1,370 Joined: 29-February 04 From: Mile High 914 Member No.: 1,729 Region Association: Rocky Mountains |
what's your test tool?
Jun 5 2011, 12:23 AM
I hope it's a good dial indicator. I tried using the feeler-gauge setup, and did not like the variability of the results.
--DD |
76-914 |
Jun 5 2011, 07:54 AM
what's your test tool? Hey Kev, I'm using everything but the kit sink. (IMG:style_emoticons/default/blink.gif) Dial indicator, feeler gages, digital calipers, you name it. The more I can confuse myself now the more excuses I'll have for later. (IMG:style_emoticons/default/lol-2.gif) How's the new digs? Did you get moved in? I hope it's a good dial indicator. I tried using the feeler-gauge setup, and did not like the variability of the results. --DD Good point. I've already discovered the feelers don't like rough surfaces. |
Lo-Fi Version | Time is now: 17th May 2024 - 08:53 PM |
