Exhaust for 914, Post a pic... |
Britain Smith |
Apr 19 2003, 12:18 AM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
Can a few people post a pick of the underside of there 914 2.0L motor (particulary the exhaust). I am trying to see how much room I will have when I mount a type-IV motor in my 912. I understand that the engine will be facing the other way, but I just want to see how everything looks.
I appreciate your help. -Britain (IMG:style_emoticons/default/confused24.gif) |
fuch toy |
Apr 19 2003, 10:06 AM
Unregistered |
Talk to Tony Bray...he's BTDT.
tony.bray@peregrine.com |
krk |
Apr 19 2003, 10:14 AM
Senior Member Group: Members Posts: 997 Joined: 27-December 02 From: San Jose Member No.: 22 |
Mike's right -- here's Tony's web page:
http://64.171.113.210/gumby/1967_porsche_912.htm And there's more links lurking in here: http://www.912registry.org/tech/engineswaps.htm kim. |
Brad Roberts |
Apr 19 2003, 10:47 AM
You walked past 150 sets of heat exchangers (you dont have the visual yet ??)
Even if we do show you pics of the underside... you will have NO reference to make any educated exhaust decisions on. Nothing remotely appears the same compared to the 912 config. Relax. Stop digging. B |
Britain Smith |
Apr 19 2003, 11:13 AM
I looked at heat exchangers for 911 sitting on the shelf. I wanted to get an idea of how they look on a 2.0L motor in a 914. Just brainstorming...
-Britain Thanks for the two links...I have seen both of them. I wanted to so something a little nicer than those stock 414 headers. |
cha914 |
Apr 19 2003, 12:36 PM
MUSR 8 - 5lug conversion done wed - drive 500miles thrus Group: Members Posts: 739 Joined: 31-December 02 From: Austin, TX Member No.: 63 |
here is a pic of a 912 header made by tangerine...nicer than the 411 exchangers, but a little more expensive also:
(IMG:http://www.tangerineracing.com/Porsche_912E_Header.jpg) Tony |
Britain Smith |
Apr 19 2003, 01:03 PM
Yea...I have seen that picture. I am trying to get someone to post a pictures of what it looks like on a 914. Either a stock set-up or whatever. I want to get a look at the position of the fan box and stuff. That image doesn't have any of that assembled.
-Britain |
Aaron Cox |
Apr 19 2003, 02:22 PM
hey, beggars cant be choosers! (IMG:style_emoticons/default/laugh.gif) jk
good luck on your search and your conversion |
Britain Smith |
Apr 20 2003, 12:36 AM
Will anyone throw me a bone here and post a pic of the underside of your motor mounted in a 914.
PLEASE... -Britain (IMG:style_emoticons/default/confused24.gif) |
rhodyguy |
Apr 20 2003, 07:55 AM
"air box and stuff"? i'm confussed( usually are). do you want to go with a upright fan shroud setup or the fan housing like most 914's? do you want interior heat? try going to shoptalkforums, the "conversion perversions" forum. lots of info with regards to dif t-4 uses. i believe a fellow named joe cali has a manual dealing with t-4 issues/turning the engine around, use the search feature there re "next generation".
kevin |
Anton |
Apr 20 2003, 03:43 PM
Royal Orange Group: Members Posts: 161 Joined: 25-March 03 From: The Netherlands Member No.: 473 |
QUOTE(Schmuck69 @ Apr 18 2003, 10:18 PM) I am trying to see how much room I will have when I mount a type-IV motor in my 912. Quite frankly I don't understand the problem; in 1976 Porsche produced the 912E which has a 2.0L type 4 engine with L-jet injection. (IMG:style_emoticons/default/ohmy.gif) Consequently, stock exhaust systems are available! The september 2002 issue of "911 and Porsche World " covers the 912E (in a direct comparison with the 914 2.0 and 924; nice reading stuff). You can order back issues through www.chpltd.com. But, there is no pic of the engine underside in the magazine (there usually isn't (IMG:style_emoticons/default/wink.gif) ). |
Lo-Fi Version | Time is now: 20th May 2024 - 03:52 AM |
