Temp gauges interchangeable? |
MikeM |
Jun 7 2011, 07:46 AM
Senior Member Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada |
Hi all...I suspected my temp gauge was not reading correctly as it would get up to about 3/4 on a cool evening, so I swapped in a gauge with the large red zone. It reads much lower but it's the gauge with the large red zone and my original was the small red zone gauge. Do these 2 gauges use the same sending unit?
Looking at the Pelican site, it appears so, but thought I'd ask the folks here... Thanks, Mike |
SUNAB914 |
Jun 7 2011, 07:56 AM
Senior Member Group: Members Posts: 698 Joined: 29-December 08 From: Fredericksburg VA Member No.: 9,880 Region Association: South East States |
Needs to match sensor. Just need to make sure engine cooling flaps and thermostat are working properly and you should be good to go. Good luck.
MikeM |
Jun 7 2011, 08:01 AM
What I have in there now is the factory sender and the large red zone gauge.
I assume the factory sender works for both style gauges??? Mike |
Tom_T |
Jun 7 2011, 09:04 AM
What I have in there now is the factory sender and the large red zone gauge. I assume the factory sender works for both style gauges??? Mike The OT gauge was wide band up to 73 MY, then narrow band 74-76. Your 74 should be narrow band, but at this age may need servicing - either North Hollywood Speedometer or Palo Also Speedo rebuilds them (both in CA). It could also be the sending unit, and if changed prior it could be different, but IIRC the same sender was used throughout. If not Cap'n Krusty or someone will jump in to correct me! (IMG:style_emoticons/default/biggrin.gif) However, check that all of your engine tins are intact, the 2 rubber lower body air flaps at the leading edge of the engine bay underside are on there - in addition to what Sunabond said about checking that the thermostat & cooling flaps are operating properly. |
Lo-Fi Version | Time is now: 18th May 2024 - 12:44 PM |
