QUOTE(MikeM @ Jun 7 2011, 07:01 AM)
What I have in there now is the factory sender and the large red zone gauge.
I assume the factory sender works for both style gauges???
Mike
The OT gauge was wide band up to 73 MY, then narrow band 74-76. Your 74 should be narrow band, but at this age may need servicing - either North Hollywood Speedometer or Palo Also Speedo rebuilds them (both in CA).
It could also be the sending unit, and if changed prior it could be different, but IIRC the same sender was used throughout. If not Cap'n Krusty or someone will jump in to correct me!
However, check that all of your engine tins are intact, the 2 rubber lower body air flaps at the leading edge of the engine bay underside are on there - in addition to what Sunabond said about checking that the thermostat & cooling flaps are operating properly.
