Need some wiring help, resolved |
sawtooth |
Jun 9 2011, 03:15 PM
Member Group: Members Posts: 297 Joined: 25-June 08 From: Boise, ID Member No.: 9,211 Region Association: Intermountain Region |
After getting the entire wiring harness back in my car, and putting in my new engman fuse panel, somehow I managed to add a feature where the ignition coil wire loses power when the starter is cranking. As soon as I let up on the starter the ignition coil wire gets 12v again. I used this wire to power my subaru ecu before, but this new behavior doesn't work so well for starting. What could I have done wrong to cause this? Possibly hooked something up backwards on the fuse panel?
The wire is the T8 black wire on the 914 relay board pinout. |
Lo-Fi Version | Time is now: 18th May 2024 - 11:30 AM |
