After getting the entire wiring harness back in my car, and putting in my new engman fuse panel, somehow I managed to add a feature where the ignition coil wire loses power when the starter is cranking. As soon as I let up on the starter the ignition coil wire gets 12v again. I used this wire to power my subaru ecu before, but this new behavior doesn't work so well for starting. What could I have done wrong to cause this? Possibly hooked something up backwards on the fuse panel?
The wire is the T8 black wire on the 914 relay board pinout.
