Engine wire harness sources?, weird jump wire discovered beneath harness plug |
Tom |
Jun 14 2011, 08:22 AM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Pin 12 will not be hot unless the fuel pump relay is energized and this only happems for 1.5 seconds when you first turn the key on, when the starter is engaged, or the engine is running. I don't think there is a problem with pin 12 not having power, as the wire melted before. Just need to be sure why before hooking up another harness. Running a temporary wire would be a good test. You will have to jumper the fuel pump relay ( remove relay and jumper pin 30 to pin 87) to do that with the rest of the harness removed.
Hey, you're welcome for the help, that what this forum is for, and I enjoy helping. Tom |
Lo-Fi Version | Time is now: 2nd June 2024 - 09:17 AM |
