Aha moment >Can You ID the Source of this Gas Leak in These Photos?, Troublesome gas smell traced to engine compartment..Please help |
c12croft |
Jun 13 2011, 06:44 PM
Member Group: Members Posts: 167 Joined: 24-December 04 From: Long Island, New York Member No.: 3,331 |
There, at the base of the Weber 40's, at the base of the passenger side carb throat was wet with gas. Huh? Engine has not run in two weeks.
Photo #1 and > gas found at base of throat at engine head Close up just as carb throat attaches to engine head Could it be a drip from above? (after sitting for two weeks??) Versus the Driver side carb which was dry of gas at same location: and There's no constant drip, just wetness at the indicated areas that are giving off the fumes that will get me evicted from inside storage. Larger view, thanks Attached image(s) |
Lo-Fi Version | Time is now: 17th May 2024 - 12:24 AM |
