There, at the base of the Weber 40's, at the base of the passenger side carb throat was wet with gas. Huh? Engine has not run in two weeks.
Photo #1
and > gas found at base of throat at engine head
Close up just as carb throat attaches to engine head
Could it be a drip from above? (after sitting for two weeks??)
Versus the Driver side carb which was dry of gas at same location:
and
There's no constant drip, just wetness at the indicated areas that are giving off the fumes that will get me evicted from inside storage.
Larger view,
thanks
