Half drive shaft challenge |
EdwardBlume |
Apr 20 2003, 02:21 PM
Anybody have some advice for pulling off the driver's side half shaft. I got the pass side off the transmission, but the driver's side wont budge.
(IMG:style_emoticons/default/ar15.gif) (IMG:style_emoticons/default/ar15.gif) (IMG:style_emoticons/default/ar15.gif) |
Brad Roberts |
Apr 20 2003, 02:23 PM
Hit the actual CV joint with a hammer. It will "pinch" itself off the pins and squeeze off.
You cant hurt it. I hope you bought some CV gaskets and grease... nasty job. Oh.. hit it on the sides of the CV. B |
Brad Roberts |
Apr 20 2003, 02:27 PM
hit it right here:
B |
EdwardBlume |
Apr 20 2003, 02:40 PM
Thanks for the advice!!! I'll give it a shot.
This is Ralph's car I'm taking apart. I'm hoping to have some parts ready for the swap if I can make it. Thanks again!! |
Brad Roberts |
Apr 20 2003, 02:48 PM
I may want the engine (if I can come up with some cash)
B |
EdwardBlume |
Apr 20 2003, 03:16 PM
The CV will not budge. I noticed theres no gasket on either side. Usually I can move the half shaft back and forth (from the wheel side to the tranny side), but its locked. Is there another way in? How tough would it be to saw???
With the engine, I can deal. Cash or cash not. You're good for it. Let me know. |
Zeke |
Apr 20 2003, 04:10 PM
Never left, but not right.... Group: Members Posts: 381 Joined: 26-January 03 From: Long Beach CA Member No.: 197 Region Association: None |
Try a big cold chisel. Hit the thing where the dowel is hiding, not where the bolts go thru. Angle the chisel away from the trans. Once or twice on eacn side rotating back and forth. Try to keep the chisel in the same place and make a little divot.
EdwardBlume |
Apr 20 2003, 04:28 PM
I can't get this piece of crap off!!!!!
Attached thumbnail(s) |
EdwardBlume |
Apr 20 2003, 04:29 PM
What will cut through it????
EdwardBlume |
Apr 20 2003, 04:44 PM
(IMG:style_emoticons/default/ar15.gif) (IMG:style_emoticons/default/ar15.gif) (IMG:style_emoticons/default/ar15.gif) (IMG:style_emoticons/default/ar15.gif) (IMG:style_emoticons/default/ar15.gif) GOT IT!!!!!!!!
Just turned the tire 180 degrees and hit it once with the hammer. This is why I make a living doing something else. Thanks!!!! (IMG:style_emoticons/default/ar15.gif) (IMG:style_emoticons/default/ar15.gif) (IMG:style_emoticons/default/ar15.gif) |
Gint |
Apr 20 2003, 07:10 PM
Mike Ginter Group: Admin Posts: 16,075 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
As long as we're on the subject, does anyone have any secret tips for getting the outer cv's off without f&%#$ng up the hub bearing? You can't really get in there to hit it at all.
brant |
Apr 20 2003, 08:07 PM
914 Wizard Group: Members Posts: 11,625 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
bump...
I need this tip as well... brant |
Brad Roberts |
Apr 20 2003, 11:34 PM
This is scary...but this is how I do it: << joke
Remove the whole thing. It doesnt F-up the bearing. Remove the stub axle nut and flip the nut over and tap on it. The stub axle/axle will come out. Then you can put the stub axle into a vise and get the CV bolts out. Then tap on it from the sides. I should have told Rob above to rotate/hit/rotate/hit. B |
Apr 21 2003, 12:04 AM
Resident German Group: Admin Posts: 41,649 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(Brad Roberts @ Apr 20 2003, 09:34 PM) Remove the whole thing. yepp, i learned about the easy way the hard way. no fun ... Andy |
Gint |
Apr 21 2003, 07:53 AM
QUOTE Brad writes: This is scary...but this is how I do it: << joke Remove the whole thing. It doesnt F-up the bearing. Remove the stub axle nut and flip the nut over and tap on it. The stub axle/axle will come out. Then you can put the stub axle into a vise and get the CV bolts out. Then tap on it from the sides. I should have told Rob above to rotate/hit/rotate/hit. That's the way I've done the last 2 sets as well. But I don't want to ruin the bearing this time and have to re-do the whole entire thing. The last 4 stub axles I pulled wouldn't come out while "tapping" on them either. It took serious BFH work to get it done. I don't see how that wouldn't ruin the bearing. Can you elaborate Brad? |
Brad Roberts |
Apr 21 2003, 08:03 AM
The bearings are press fit with the hub into one side of the wheel bearing. Your removing one side of the compression. The bearing will feel like toast if you role the car around without the stub axle. Put the stub axle back in and tighten the nut a "little" so you can role the car around and NOT ruin the bearings. They always feel loose when the stub axle is out.
When you go back together... put anti-seize on them so you can get it apart later if need be. I know the stubs can be difficult...but I have not ruined a bearing getting them out. B |
brant |
Apr 21 2003, 08:59 AM
I too thought that driving out the stub would ruin the bearing by applying force to the wrong surface........
now I'm confused... Is there any other tricks out there.. maybe I'll give it a try. brant |
Brad Roberts |
Apr 21 2003, 09:02 AM
The stub is not a press fit into the bearing. It just holds one side of the bearing. The drive flange goes all the way into the bearing. The stub axle is what holds everything together in compression.
B |
Lo-Fi Version | Time is now: 20th May 2024 - 12:50 AM |
