> What size is the bolt, For the rear outer suspension console
MrHyde
post Jun 21 2011, 07:37 AM
Can someone please tell me what the size is for the outer rear suspension console to the trailing arm ears... when I tool the arms off my parts car all 6 bolts were rusted, siezed and snaped... (IMG:style_emoticons/default/blink.gif)
Thanks,
Mike
URY914
post Jun 21 2011, 07:46 AM
8 mm, 13 mm wrench size.
MrHyde
post Jun 21 2011, 08:00 AM
What would be the thread pitch ? fine or coarse thread.. and length.. So I can find some new bolts... Thx
URY914
post Jun 21 2011, 12:11 PM
Course pitch. Don't know the length off hand but they don't bottom out in the hole so longer is not a problem.
Cap'n Krusty
post Jun 21 2011, 12:34 PM
Cap'n Krusty
I disagree. I think they're 10x55mm, 1.5 thread pitch. 900 074 192 01. But, of course, I could be wrong.
The Cap'n
TheCabinetmaker
post Jun 21 2011, 01:30 PM
I drive my car everyday
QUOTE(Cap'n Krusty @ Jun 21 2011, 01:34 PM) *
The Cap'n
I seriously doubt that. You might read the q wrong, but the answer is right. (IMG:style_emoticons/default/beerchug.gif)
r_towle
post Jun 21 2011, 02:15 PM
Custom Member
I noticed a really nice replacement idea on Chris Foley's website.
Using a hole saw you can remove the threaded bung (with the broken bolt inside) and weld in a new replacement bung...
Having drilled out two broken bolts from a friends car I can honsetly say I would never try that again...
They are hardened bolts and you need to get cobalt drill bits to get them out, plus you need to build a centering tool so you can get in far enough, and in the center to drill them out.
Rich
MrHyde
post Jun 21 2011, 03:43 PM
Well I'll be putting the suspension on my new(ish) body.and it has good nut inserts in it. I just need to know what bolts to buy. :-)
Cap'n Krusty
post Jun 21 2011, 04:20 PM
Cap'n Krusty
QUOTE(MrHyde @ Jun 21 2011, 02:43 PM) *
Read my earlier post.
The Cap'n
ChrisFoley
post Jun 21 2011, 06:26 PM
I am Tangerine Racing
QUOTE(URY914 @ Jun 21 2011, 09:46 AM) *
That size might be big enough to keep your trailing arms in place Paul but most of us have cars which weigh more than 2000lbs. (IMG:style_emoticons/default/biggrin.gif)
MrHyde
post Jun 22 2011, 01:05 AM
Thanks guys ! (IMG:style_emoticons/default/smile.gif)
Eric_Shea
post Jun 22 2011, 09:11 AM
PMB Performance
Just to confirm... Cap'n is correct.
For all of these types of questions, there's no source like the horse:
http://www.porsche.com/usa/accessoriesands...partscatalogue/
URY914
post Jun 22 2011, 10:42 AM
QUOTE(URY914 @ Jun 21 2011, 06:46 AM) *
Nope. I just checked my car( Easy to do being it's on jack stands. (IMG:style_emoticons/default/sad.gif) )
They are 10mm, 17mm wrench size.
The Cap't was correct. (As is the norm.) (IMG:style_emoticons/default/rolleyes.gif)
MrHyde
post Jun 22 2011, 12:00 PM
Thanks for the link Eric !
on jack stands.... funny.. I know I can't get anymore 914's because I've run out of jackstands....
TargaToy
post Oct 2 2011, 01:47 PM
-NONSOLIS RADIOS SEDIOUIS FULMINA MITTO-
Where do you guys get these bolts (or safe replacements) when needed?
I need 1 but want to replace all 6.
Eric_Shea
post Oct 2 2011, 10:51 PM
PMB Performance
Www.McMaster.com
TargaToy
post Oct 3 2011, 08:58 PM
Thanks, Eric.
- Lo-Fi Version Time is now: 13th July 2025 - 10:33 AM
