MrHyde
Jun 21 2011, 07:37 AM
Can someone please tell me what the size is for the outer rear suspension console to the trailing arm ears... when I tool the arms off my parts car all 6 bolts were rusted, siezed and snaped...
Thanks,
Mike
URY914
Jun 21 2011, 07:46 AM
8 mm, 13 mm wrench size.
MrHyde
Jun 21 2011, 08:00 AM
What would be the thread pitch ? fine or coarse thread.. and length.. So I can find some new bolts... Thx
URY914
Jun 21 2011, 12:11 PM
Course pitch. Don't know the length off hand but they don't bottom out in the hole so longer is not a problem.
Cap'n Krusty
Jun 21 2011, 12:34 PM
I disagree. I think they're 10x55mm, 1.5 thread pitch. 900 074 192 01. But, of course, I could be wrong.
The Cap'n
TheCabinetmaker
Jun 21 2011, 01:30 PM
QUOTE(Cap'n Krusty @ Jun 21 2011, 01:34 PM)
The Cap'n
I seriously doubt that. You might read the q wrong, but the answer is right.
r_towle
Jun 21 2011, 02:15 PM
I noticed a really nice replacement idea on Chris Foley's website.
Using a hole saw you can remove the threaded bung (with the broken bolt inside) and weld in a new replacement bung...
Having drilled out two broken bolts from a friends car I can honsetly say I would never try that again...
They are hardened bolts and you need to get cobalt drill bits to get them out, plus you need to build a centering tool so you can get in far enough, and in the center to drill them out.
Rich
MrHyde
Jun 21 2011, 03:43 PM
Well I'll be putting the suspension on my new(ish) body.and it has good nut inserts in it. I just need to know what bolts to buy. :-)
Cap'n Krusty
Jun 21 2011, 04:20 PM
QUOTE(MrHyde @ Jun 21 2011, 02:43 PM)
Read my earlier post.
The Cap'n
ChrisFoley
Jun 21 2011, 06:26 PM
QUOTE(URY914 @ Jun 21 2011, 09:46 AM)
That size might be big enough to keep your trailing arms in place Paul but most of us have cars which weigh more than 2000lbs.
MrHyde
Jun 22 2011, 01:05 AM
Thanks guys !
Eric_Shea
Jun 22 2011, 09:11 AM
Just to confirm... Cap'n is correct.
For all of these types of questions, there's no source like the horse:
http://www.porsche.com/usa/accessoriesands...partscatalogue/
URY914
Jun 22 2011, 10:42 AM
QUOTE(URY914 @ Jun 21 2011, 06:46 AM)
Nope. I just checked my car( Easy to do being it's on jack stands.
They are 10mm, 17mm wrench size.
The Cap't was correct. (As is the norm.)
MrHyde
Jun 22 2011, 12:00 PM
Thanks for the link Eric !
on jack stands.... funny.. I know I can't get anymore 914's because I've run out of jackstands....
TargaToy
Oct 2 2011, 01:47 PM
Where do you guys get these bolts (or safe replacements) when needed?
I need 1 but want to replace all 6.
Eric_Shea
Oct 2 2011, 10:51 PM
Www.McMaster.com
TargaToy
Oct 3 2011, 08:58 PM
Thanks, Eric.
