HELP :Headlight motor causing battery drain, Headlight motor runs when I connect up a replacement battery |
c12croft |
Jun 22 2011, 11:07 AM
Member Group: Members Posts: 167 Joined: 24-December 04 From: Long Island, New York Member No.: 3,331 |
Installed my battery following a short term storage only to find that as soon as I connected the lugs (with ignition key out) the passenger side headlamp motor started running (without moving the lamp position), kinda just making a whinning noise continuously. It only stopped when I disconnected the three-lead (red,green, grey wires) of the headlight motor.
I did a search trying to troubleshoot this problem with no luck. Anyone suggest what I should check for? Thanks |
tdgray |
Jun 22 2011, 12:27 PM
Thank God Nemo is not here to see this Group: Members Posts: 9,705 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None |
Faulty Relay (round replay on the top of the motor).
Swap it out with the one from the other side and test. |
c12croft |
Jun 22 2011, 04:45 PM
Jun 22 2011, 06:59 PM
914 Idiot Group: Members Posts: 14,982 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Nope, that is just a knob.
There is a cylinder-shaped plastic relay that is plugged into the side of the headlight mechanism. In early cars I think it is hidden behind a plastic cover. Check on the side of the headlight bucket that faces the trunk. The relays are exactly the same as the ones on the relay board in the engine bay. --DD |
tdgray |
Jun 23 2011, 08:25 AM
Dave is correct.... sorry I said top but that is not what I meant (apparently I have been without a 914 for too long).
c12croft |
Jun 23 2011, 11:22 AM
AhhSoo......
Said relay is hiding behind plastic cover shown in this picture? A bad relay could cause the headlight motor to run withuout the ignition key even on? This relay is on both Pass and Driver sides? |
tdgray |
Jun 23 2011, 01:39 PM
AhhSoo...... Said relay is hiding behind plastic cover shown in this picture? A bad relay could cause the headlight motor to run withuout the ignition key even on? This relay is on both Pass and Driver sides? Possibly... yes one for each side... swap the good side to the bad side and see if it works... as Dave said... same relays on the board in engine compartment |
Lo-Fi Version | Time is now: 9th May 2024 - 09:34 PM |
