Just picked my car up from the shop, Where's 4th gear? |
MikeSpraggi |
Jun 22 2011, 09:07 PM
Senior Member Group: Members Posts: 781 Joined: 7-February 05 From: Silver Spring, Md Member No.: 3,570 Region Association: MidAtlantic Region |
Picked up my car from the shop just as they were closing this evening. Going to Watkins Glen in the morning for three days of PCA DE. I stopped to get a bite to eat at the corner so about 30 minutes later I start to drive home. 2nd, 3rd ..... ugh! 3rd .... 3rd ... 5th. Couldn't get it into 4th. On the highway same thing except when I downshifted I pushed it into 4th with a bit of effort. No grinding, the gearing felt right. Upshifting though it's feels like something just stopping it from going easily into 4th. Once in my driveway at a standstill, I can get it into 4th but there is a strong resistance as I move it into gear. It's dark outside right now so I'll take a look in the AM. Any thoughts on what could be causing this? Oh yea, it's a sideshifter.
Jun 22 2011, 09:52 PM
914 Idiot Group: Members Posts: 14,983 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Clutch tube interfering with the bottom side of the gear shift lever? You can take a look through the shifter base to see if the lever contacts the tube.
--DD |
campbellcj |
Jun 22 2011, 09:56 PM
I can't Re Member Group: Members Posts: 4,544 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
If it's the clutch tube you may be able to feel and hear the broken tube moving as the shift rod pushes it aside. Bummer, I hope you figure it out for your event!
MikeSpraggi |
Jun 22 2011, 10:07 PM
Thanks all. I'll take a look in the morning.
John |
I was having a PITA time shifting my track car and it turned out to be the shift coupling bushings (one was completely missing).
Lo-Fi Version | Time is now: 10th May 2024 - 12:49 PM |
