Ball joint nut tool |
Ductech |
Jun 23 2011, 12:34 PM
Member Group: Members Posts: 356 Joined: 16-July 10 From: AridZona Member No.: 11,949 Region Association: Southwest Region |
Anyone in the northwest that has a special tool or one of those ford front end sockets? I need to install a set of ball joints!
Thanks for the help guys! |
Jun 23 2011, 12:43 PM
large pipe wrench works quite well.
Rich |
ArtechnikA |
Jun 23 2011, 12:52 PM
Anyone in the northwest that has a special tool or one of those ford front end sockets? I need to install a set of ball joints! As the other Rich observes - big pipe wrench works. I install them 'hand-snug' to make sure everything is seated (after applying some kind of anti-sieze to the threads) and then use a dull chisel or solid punch to drive the nut on tight. There is a torque spec, but 'pretty darned tight' will do. It's not going anywhere if you re-install the serrated retainer... |
VaccaRabite |
Jun 23 2011, 12:54 PM
Thirded on the pipe wrench.
Zach |
914werke |
Jun 23 2011, 01:26 PM
"I got blisters on me fingers" Group: Members Posts: 10,052 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Ive used both (chisel & pipe wrench) depending on the level of corrosion plan on destroying the "nut"
Robert I have a tool. stop by to borrow it (but be prepared to be recruited to lend me a hand for the favor (IMG:style_emoticons/default/smile.gif) ) The Porsche tool is pretty spendy for how infrequently you might use it. Mine isnt a Porsche ver but works. |
Ductech |
Jun 23 2011, 02:53 PM
Ive used both (chisel & pipe wrench) depending on the level of corrosion plan on destroying the "nut" Robert I have a tool. stop by to borrow it (but be prepared to be recruited to lend me a hand for the favor (IMG:style_emoticons/default/smile.gif) ) The Porsche tool is pretty spendy for how infrequently you might use it. Mine isnt a Porsche ver but works. I forgot to mention that I already took the ball joints out (IMG:style_emoticons/default/smile.gif) rdauenhauer I might just give you a ring later today... what kinda favor you need? I guess i'm a stickler for torque specs.... didn't want to install them without knowing they are F***ing tight. Right now I am torturing myself with a crappy seudo plastic suspension busing install. |
Eric_Shea |
Jun 23 2011, 10:11 PM
Someone has mine! Loaned it out here and never got it back... (IMG:style_emoticons/default/mad.gif)
Lo-Fi Version | Time is now: 10th May 2024 - 01:04 AM |
