is this an engine alternative , bmw R boxer engine, 90 horse , air / oil cooled , poke holes here please |
thelogo |
Jun 23 2011, 01:32 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
http://cgi.ebay.com/ebaymotors/Complete-BM...s#ht_3607wt_941
ebay link . 2k (IMG:style_emoticons/default/bye1.gif) is this a viable engine alternative to subaru. (IMG:style_emoticons/default/stirthepot.gif) because I hate radiators . (IMG:style_emoticons/default/sawzall-smiley.gif) what challenges would this bmw engine present ??? (IMG:style_emoticons/default/chair.gif) Attached thumbnail(s) Attached image(s) |
jmill |
Jun 23 2011, 01:46 PM
At only 90hp why not stick with a stock 2.0?
wingnut86 |
Jun 23 2011, 01:53 PM
...boola la boo boola boo... Group: Members Posts: 1,053 Joined: 22-April 10 From: South Carolina Member No.: 11,645 Region Association: South East States |
IMO
1- You'll need sheet aluminum or steel to create your own tin set to redirect airflow 2- CNC a custom fabricated plate to move the accessories package to a horizontal position/plane for fit 'n' function in a teener - this may require a beefier end shaft - then beefier crank/etc - depends on if you have to extend the shaft to accomidate this (IMG:style_emoticons/default/blink.gif) 3- Good luck with the ECU when you do all of the above 4- It's easier to modify a V-Dub tranny with a 4 speed than the same with a 901, but it would be fun 5- The oil sump area is too small and I believe a separate oil cooler/larger would be needed 6- Everyone will definitely say your car sounds like a Suzuki from the early 80's with any pipe setup (IMG:style_emoticons/default/WTF.gif) 7- Lastly, 90HP aside, the teener body should be all Carbon for weight reduction, sitting on a light tube frame design - that motor was designed to wrap a 180lb groin around if you get my drift ...other than that - Piece of Cake... (IMG:style_emoticons/default/aktion035.gif) |
VaccaRabite |
Jun 23 2011, 01:54 PM
Designed to push a 500lbs bike. May not have the torque to push a 2400lbs car.
And no power improvement over stock. So... Why? Zach |
Tom_T |
Jun 23 2011, 04:10 PM
Designed to push a 500lbs bike. May not have the torque to push a 2400lbs car. And no power improvement over stock. So... Why? Zach (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) Lower TQ & only 2 bangers with 90 hp - vs. 72 in your 73 1.7 (80 if not a CA 73 1.7). (IMG:style_emoticons/default/huh.gif) You can build your 1.7 to 1911 +/- & get about 100 HP & 2x the R1100's TQ on stock D-jet, with far less work & stay smog exempt - so why!!?? (IMG:style_emoticons/default/confused24.gif) |
Mark Henry |
Jun 23 2011, 04:55 PM
It would be easier and more cost effective to put a type 1 beetle engine in it.
thelogo |
Jun 23 2011, 04:57 PM
At only 90hp why not stick with a stock 2.0? well I was thinking along the lines of yes same out put as 2.0 but , lighter weight = faster , higher revving . modern induction / f i low maintence ? longevity ? most importantly , to me is : ability to return to 100 completely stock engines if I or future owner should desire , ??? but yes I understand , add's complexity is a con . |
thelogo |
Jun 23 2011, 05:00 PM
I through it against the wall an see if it sticks , not this time
(IMG:style_emoticons/default/beer3.gif) |
messix |
Jun 23 2011, 05:20 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
do it and report back.... the world is flat......
might be a fun build! |
Mike Bellis |
Jun 23 2011, 10:45 PM
Torque moves the car not HP. It has the same HP but no torque. It will be very sluggish off the line but may be able to maintain hwy speeds after a few miles at WOT.
Ductech |
Jun 24 2011, 12:11 AM
Member Group: Members Posts: 356 Joined: 16-July 10 From: AridZona Member No.: 11,949 Region Association: Southwest Region |
And I thought that putting a subaru motor in ruined one of these things. This would be like buying a big two stroke 500 cc dirt bike and putting a 250 four stroke in it. Just wouldn't pan out very well.
Jun 24 2011, 12:23 AM
Resident German Group: Admin Posts: 41,626 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Torque moves the car not HP. It has the same HP but no torque. It will be very sluggish off the line but may be able to maintain hwy speeds after a few miles at WOT. (IMG:style_emoticons/default/agree.gif) |
FourBlades |
Jun 24 2011, 06:42 AM
From Wreck to Rockin Group: Members Posts: 2,054 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States |
Look how small it is, just put two of them in there, maybe one in the front trunk for 4wd... (IMG:style_emoticons/default/happy11.gif) 180 HP and air cooled and 4wd. John |
DBCooper |
Jun 24 2011, 02:05 PM
You know there are kits to do the reverse, put four banger VW engines into BMW R bikes. There's even a Yahoo group for them. But I believe you're the first I've heard thinking about the opposite.
I have several bikes with those engines and I don't think you'd be happy with them in a car that weighs four times as much as the bike did. The only way you're supposed to leave one of those idling for any amount of time, when balancing the throttle bodies for example, is with a big fan in front of the bike for engine cooling air circulation. There have supposedly been bikes burst into flame when the owner left a bike idling in the garage while he was distracted in the house. Let me repeat: Burst into Flames. Not good in a car, no. |
Dr Evil |
Jun 24 2011, 04:22 PM
Bolt two together, then install (IMG:style_emoticons/default/smile.gif)
There are better motorcycle engines out there (IMG:style_emoticons/default/wink.gif) |
thenewwazoo |
Jun 25 2011, 09:29 AM
Member Group: Members Posts: 56 Joined: 3-October 09 From: RWC Member No.: 10,883 Region Association: Northern California |
If you want to talk bike engines, let's talk Hayabusa or ZX-14 engines. 175+ HP, very lightweight, enough torque. I've got notes somewhere about the work required. They're Megasquirt-able, and can be mated to a Quaife chain-drive differential (with reverse, even!). If you want to go with a "standard" transmission, the Miatabusa project has done the R&D required to mate it to a Miata trans. I don't think an Audi trans would be a huge amount more work, if you've got the $$$.
DBCooper |
Jun 25 2011, 10:40 AM
Better car engines out there too (wink wink). I like my oilheads, they have... um... character. In the parking at a vintage car race in the U.K. I saw a Mini with a Hayabusa engine in the rear passenger seat All stock looking from the outside but gutted, full cage, fiberglass sheet metal parts, lexan windows, the car couldn't have weighed 1000 lbs. Looked like a full half ton of fun. |
Kraftwerk |
Jun 25 2011, 01:26 PM
Member Group: Members Posts: 195 Joined: 6-September 07 From: Bbbbbrroooklynnn Member No.: 8,085 |
Put two of 'em in and have 180 Hp!
Only way to do it. |
Lo-Fi Version | Time is now: 11th May 2024 - 06:27 AM |
