Rear Trunk Hood Holders...Interest?, The plastic and rubber bits |
thesey914 |
Jun 16 2004, 03:13 AM
Senior Member Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 |
I want some please
JWest |
Jun 16 2004, 06:07 AM
I can't see the point in making the rears if they are made from the same material, and I doubt you could beat the current price anyway, but if you could make them from more flexible (silicone?) rubber then I would like some.
I am always afraid the rubber is going to snap off because they are so inflexible (even when new). To me, the fronts seem fine in stock form as long as they are not 20 years old brittle. They can flex quite a bit without breaking when they are relatively new. |
davep |
Jun 16 2004, 11:39 AM
914 Historian Group: Benefactors Posts: 5,151 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
The front clips appear to be nylon. If so, soak them in hot water every once in a while. The nylon is hydroscopic and will absorb some water. Water actually makes them stronger.
We make nylon ice scraper blades. Dry the nylon very well before molding, then soak in water for a day after molding. What fun. |
mike_the_man |
Jun 16 2004, 01:24 PM
I like stuff! Group: Members Posts: 1,338 Joined: 11-June 03 From: Regina, Saskatchewan, Canada Member No.: 809 |
I'd be up for some. Those pieces are lower on my list of things I need, but if the price is right...
(Of course I'm a cheap bastard) |
Dave Bell |
Jun 16 2004, 02:13 PM
Member Group: Members Posts: 234 Joined: 27-November 03 From: Santa Clarita, CA Member No.: 1,398 Region Association: None |
Did someone say cheap?... count me in for a set or two.
- Dave |
tat2dphreak |
Jun 16 2004, 02:42 PM
I'll take a set of the rubber ones if they are softer and/or cheaper (IMG:style_emoticons/default/wink.gif)
Jenny |
Jun 16 2004, 02:49 PM
Advanced Member Group: Members Posts: 4,060 Joined: 6-January 03 Member No.: 96 Region Association: None |
Interested. Three of four are broken or missing.
Jen |
thesey914 |
Jun 16 2004, 03:32 PM
We should all expect to pay more if the product is superior
GWN7 |
Jun 17 2004, 07:59 PM
I'll have samples on Monday.... they are being made of a softer material than the front pieces and harder than the rear.
It has a 300 lbs per liner inch tear strenght and will take a 600% elongation before breaking. Looks good so far. I had a chance to play with the material they will be made of today. I'll have one of each (one front and one of each rear, left & right) to play with. Will post Andyesque pictures when I get them.. (IMG:style_emoticons/default/biggrin.gif) |
Joe Bob |
Jun 17 2004, 08:13 PM
GWN7 |
Jun 17 2004, 08:33 PM
PM me your address....
dakotaewing |
Jun 17 2004, 10:27 PM
Senior Member Group: Members Posts: 1,160 Joined: 8-July 03 From: DeSoto, Tx Member No.: 897 Region Association: Southwest Region |
The Bullett is going to some..... (IMG:style_emoticons/default/ar15.gif) (IMG:style_emoticons/default/fighting19.gif)
I'm in for at least one set of each...2 if they are cheap enough.... Thom |
redshift |
Jun 17 2004, 10:28 PM
I need 10,000 sets, pronto!
Email them? M |
Levi |
Jun 18 2004, 12:12 AM
Lick my nuts Group: Benefactors Posts: 623 Joined: 11-March 04 Member No.: 1,783 |
I'm in...
markb |
Jun 18 2004, 12:50 AM
Add me to the list, please.
ablose58 |
Jun 18 2004, 04:20 AM
rust never sleeps Group: Members Posts: 584 Joined: 6-December 03 From: port orchard,wa. Member No.: 1,422 |
I'm in for a set of rears (IMG:style_emoticons/default/smilie_pokal.gif) AL
GWN7 |
Jun 23 2004, 06:24 PM
Got the samples back today....they look and feel good....
Specs: Elongation at break....550% Tensile Strength........2000 psi Tear strength..............300pli Shore A Hardness.........90 (the original rear ones have a Shore A Hardness rating of 80) Attached image(s) |
GWN7 |
Jun 23 2004, 06:25 PM
andyesque pic two....
GWN7 |
Jun 23 2004, 06:26 PM
three...
GWN7 |
four....
Lo-Fi Version | Time is now: 4th June 2024 - 01:47 PM |
