Jump-crank help |
Jump-crank help |
pete |
Jun 27 2011, 02:42 PM
Member Group: Members Posts: 158 Joined: 23-August 10 From: New Jersey Member No.: 12,092 Region Association: North East States |
I bought this starter off ebay. I bolted it to my trans and would like to see if it turns my SBC 350 over. How do I jump it? I don't want to start the engine. I just want to make sure it engages the flywheel and cranks the engine. I connected jumper cables to my car battery and connected the hot lead to the top of the starter under that black boot and touched steel with the neg lead. It spun the starter gear but didn't extend it. I connected a wire to the spade terminal under the starter and touched that with the hot lead and the neg to ground and it extended the gear but wouldn't spin it. I jumped the spade terminal on the starter to the ground I was using and touched both with the hot lead and it just spun, wouldn't engage. Any thoughts?
Jun 27 2011, 02:55 PM
hook up your jumper to the bottom large nut and then use a small alligator clip lead to energize the spade stud next to it.
The solenoid kicks the gear into the flywheel. You need to energize the motor via the solenoid. Rich |
Bruce Hinds |
Jun 27 2011, 03:00 PM
V-8 madness Group: Members Posts: 733 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest |
I've never seen one of those.....What kind of starter is that?
SLITS |
Jun 27 2011, 05:46 PM
I've never seen one of those.....What kind of starter is that? It's a Jap gear reduction starter with a new nose machined to fit Porsche. Can't remember if the base starter is Nippondenso or Hitachi. Made by IMI. Better ones are made by Proline out of Parker, AZ. |
pete |
Jun 28 2011, 06:46 AM
I've never seen one of those.....What kind of starter is that? This starter was recommended to me for my V8 conversion. Here is the Ebay link. http://cgi.ebay.com/ebaymotors/ws/eBayISAP...atchlink:top:en It seems to be a solid unit and a very good fit although I haven't tested it yet. |
pete |
Jun 28 2011, 06:49 AM
hook up your jumper to the bottom large nut and then use a small alligator clip lead to energize the spade stud next to it. The solenoid kicks the gear into the flywheel. You need to energize the motor via the solenoid. Rich Hey Rich, so I should use a alligator clip/wire and clip it to the spade and the other end to the large lower nut? Then connect the hot jumper cable to the nut and the negative to a suitable ground? |
SLITS |
Jun 28 2011, 07:35 AM
hook up your jumper to the bottom large nut and then use a small alligator clip lead to energize the spade stud next to it. The solenoid kicks the gear into the flywheel. You need to energize the motor via the solenoid. Rich Hey Rich, so I should use a alligator clip/wire and clip it to the spade and the other end to the large lower nut? Then connect the hot jumper cable to the nut and the negative to a suitable ground? The answer would be yes, but you do not leave the alligator clip secured to the spade terminal. You jump between the battery lead on the starter and the spade terminal to get the starter to function. In a normal situation, when you turn the key to start position, switched power is supplied from the ignition switch to the solenoid (big yellow wire). This energizes the solenoid which shoots the bendix out to engage the flywheel teeth and engages contacts (inside the solenoid) to supply battery voltage to the starter motor. When the key is released to the run position, the power to the solenoid & starter is cut off. Oh BTW, the IMI brand was started by Pat Isom, Isom Brothers Rebuilding (electrical rebuilders), in Whittier, CA. He downed the business a few years ago due to health reasons and someone took over the IMI Line. |
pete |
Jun 28 2011, 07:48 AM
hook up your jumper to the bottom large nut and then use a small alligator clip lead to energize the spade stud next to it. The solenoid kicks the gear into the flywheel. You need to energize the motor via the solenoid. Rich Hey Rich, so I should use a alligator clip/wire and clip it to the spade and the other end to the large lower nut? Then connect the hot jumper cable to the nut and the negative to a suitable ground? The answer would be yes, but you do not leave the alligator clip secured to the spade terminal. You jump between the battery lead on the starter and the spade terminal to get the starter to function. In a normal situation, when you turn the key to start position, switched power is supplied from the ignition switch to the solenoid (big yellow wire). This energizes the solenoid which shoots the bendix out to engage the flywheel teeth and engages contacts (inside the solenoid) to supply battery voltage to the starter motor. When the key is released to the run position, the power to the solenoid & starter is cut off. Oh BTW, the IMI brand was started by Pat Isom, Isom Brothers Rebuilding (electrical rebuilders), in Whittier, CA. He downed the business a few years ago due to health reasons and someone took over the IMI Line. Great. Thanks Ron. I'll try it today. |
pete |
Jun 28 2011, 02:11 PM
hook up your jumper to the bottom large nut and then use a small alligator clip lead to energize the spade stud next to it. The solenoid kicks the gear into the flywheel. You need to energize the motor via the solenoid. Rich Hey Rich, so I should use a alligator clip/wire and clip it to the spade and the other end to the large lower nut? Then connect the hot jumper cable to the nut and the negative to a suitable ground? The answer would be yes, but you do not leave the alligator clip secured to the spade terminal. You jump between the battery lead on the starter and the spade terminal to get the starter to function. In a normal situation, when you turn the key to start position, switched power is supplied from the ignition switch to the solenoid (big yellow wire). This energizes the solenoid which shoots the bendix out to engage the flywheel teeth and engages contacts (inside the solenoid) to supply battery voltage to the starter motor. When the key is released to the run position, the power to the solenoid & starter is cut off. Oh BTW, the IMI brand was started by Pat Isom, Isom Brothers Rebuilding (electrical rebuilders), in Whittier, CA. He downed the business a few years ago due to health reasons and someone took over the IMI Line. I connected a switch I found in my junk box to the solenoid with two alligator clipped wires and used my forklift battery to energize the starter. Cranked great! Thanks for your help everyone. |
Jun 28 2011, 02:15 PM
looks perfect, now duct tape everything in place (make sure you use plenty of dielectric grease) and it should work fine for a year or so.
Rich |
Bruce Hinds |
Jun 28 2011, 05:09 PM
It seems to be a solid unit and a very good fit although I haven't tested it yet. [/quote] I was just curious, I got by with a 914 starter on my renegade conversion for years, it seemed to have enough torque for the 9:1 compression V8 but eventually started skipping teeth because the bearing in the end was not up to the task of 4 impulses per revolution. Perhaps the high torque gets past that, but it was all about bearing size. I ended up having to change out the ring gear and went with a reverse rotation Chevy unit from Kennedy. |
jimkelly |
Jun 29 2011, 12:33 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
yes we carry the IMI-101 high torque starter for $185.
KENNEDY ENGINEERED PRODUCTS, INC. 661-272-1147 38830 17th St. E Fax: 661-272-1575 Palmdale, CA 93550 www.kennedyenginc.com www.kennedyeng.com |
Lo-Fi Version | Time is now: 12th May 2024 - 11:47 AM |
