Does this part exist, Rust in left fron torsion bar mount |
veltror |
Jun 28 2011, 07:56 AM
Senior Member Group: Members Posts: 928 Joined: 27-April 08 From: Potters Bar Herts UK Member No.: 8,978 Region Association: None |
I was wondering if the part where the left tornsion bar front, is mounted exists as a repair panel
http://www.914world.com/bbs2/index.php?s=&...t&p=1039858 Can i use a 911 repir part if one exists? Now that we have delved into this, it looks a bit worse then i expected? Any ideas? (IMG:style_emoticons/default/welder.gif) Roman |
Bartlett 914 |
Jun 28 2011, 08:41 AM
Advanced Member Group: Members Posts: 2,215 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
I was wondering if the part where the left tornsion bar front, is mounted exists as a repair panel http://www.914world.com/bbs2/index.php?s=&...t&p=1039858 Can i use a 911 repir part if one exists? Now that we have delved into this, it looks a bit worse then i expected? Any ideas? (IMG:style_emoticons/default/welder.gif) Roman It may be available. If not, you can get one off a donor car. This may be the best way to go. There should be plenty around. |
Jun 28 2011, 09:44 AM
you will need a front trunk floor pan also.
I suggest you send that pic to restoration design to see if they can help you out. Rich |
veltror |
Jun 28 2011, 12:05 PM
ta, I will do that lots of donor cars in the UK, err no....
GaroldShaffer |
Jun 28 2011, 01:10 PM
You bought another 914? Group: Benefactors Posts: 7,621 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
ta, I will do that lots of donor cars in the UK, err no.... While that maybe true in the UK, there are plenty here in the USA. I would contact restoration design like Rich said and / or post extactly the size of the section you need plus a little extra so it can be trimed to fit. There is a guy on the Samba in FS section that is going to cut up and scrap a 914 see this LINK Place a WTB add here, the club, and pelican. Good luck. I give you credit for saving another 914 (IMG:style_emoticons/default/beerchug.gif) |
Jun 28 2011, 01:23 PM
914-6 GT in waiting Group: Members Posts: 19,258 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Recent post for cutting up a car - http://www.914world.com/bbs2/index.php?sho...=131329&hl=
Lo-Fi Version | Time is now: 10th May 2024 - 07:18 AM |
