6 vs 4, a different question |
Jun 29 2011, 03:06 PM
So,
I had never had the chance to drive a 911 or a 914/6 before. I now own a 3.2 carerra cab...and I must say its an impressive motor. Quiet...no valve rap is the first thing that gets me smiling. Second is that it has more power than I have found road to use safely. Sure I run it up in second or third....but I never push it all the way through 5th... So, I love the torque...what a refreshing difference. The support for parts is very strong, and the fuel injection is simple and still quite fixable. So, if I budget 5-8k for a type 4 monster... OR 5-8k for an installed and running 3.2 or 3.6 motor. Can the 6 be done for that? I do all my own work...so labor is free. If I could find a 4k motor, that would do the trick..I keep seeing them for 5-8k just for the motor....that is to much for me to make this leap... a 5-8k type 4 motor would also make me smile alot... Rich |
Cap'n Krusty |
Jun 29 2011, 03:14 PM
Try 10-12K, on a budget with long wait times for "just the right deals'" to come along.
BTDT, with a $3K motor, more than once. |
Jun 29 2011, 03:24 PM
Resident German Group: Admin Posts: 41,626 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
There are deals out there, but they are hard to come by.
$4k for a good motor might be a stretch ... (IMG:style_emoticons/default/popcorn[1].gif) |
Andyrew |
Jun 29 2011, 03:41 PM
I say you go 4 cyl or go water cooled.
Pushing a 6 conversion isnt going to be in that price range.. How much did Trekkor do his for? |
Jun 29 2011, 03:48 PM
How much did Trekkor do his for? I think he paid $1500 for his motor. You can wait years for a deal like that to come by ... (IMG:style_emoticons/default/shades.gif) |
Andyrew |
Jun 29 2011, 04:10 PM
I know (IMG:style_emoticons/default/smile.gif)
I just remember he did it for a record low number. He had to rebuild his motor after a couple of seasons no? (Wait, he went bigger right?) |
Jun 29 2011, 04:14 PM
4k for a motor that needs head gaskets?
The early 3.6 liter ones? Rich |
Jun 29 2011, 04:21 PM
4k for a motor that needs head gaskets? The early 3.6 liter ones? A running 3.6L is in the $8k range. I've never seen one for $4k. (IMG:style_emoticons/default/chowtime.gif) |
Jun 29 2011, 04:22 PM
914-6 GT in waiting Group: Members Posts: 19,260 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Even if the engine is free:
oil lines oil tank engine sheetmetal engine mount fuel lines engine wire harness throttle linkage headers exhaust 911 fuel pump 911 starter 911 tach 911 oil guage misc hardware misc mods might need carbs or DME fan shroud on 3.2 clutch & flywheel gaskets and seals aux oil cooler stronger CV's bigger brakes ect. $5K +++ in parts Just my opinion. Mark |
patssle |
Jun 29 2011, 04:27 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
Timing can affect the price. Also, what you already have or don't have. I'm in the middle of a conversion and I saved a few bunch through group buys on the engine tin and oil tank - and a Christmas sale for headers.
3.2 or 3.6 might jack the price up though, would you stick with the 901 or need to convert to a 915? I'm staying with the 901 with my 3.0L. That's about its limit (and I'll still have to be careful). |
Jun 29 2011, 04:40 PM
would you stick with the 901 or need to convert to a 915? I'm staying with the 901 with my 3.0L. That's about its limit I tend to dis-agree. I've been running a stock 901 behind my 3.6L for several years now. So far, no problems at all. (IMG:style_emoticons/default/bye1.gif) |
Jun 29 2011, 05:07 PM
I'm using a 3.2/901 combo. 901 trans is light, cheap and pretty much a bolt on.
jmill |
Jun 29 2011, 05:08 PM
I'll have 15k easy into my engine conversion before it's done. That includes over 4k for new p/c's. You could minus that if you don't need them. Chances are an engine that doesn't need them will cost you 4k more. Sad to say that cost is just to put in a peppy 2.4.
MDG |
Jun 29 2011, 05:17 PM
Wolf in wolf's clothing. Group: Members Posts: 8,652 Joined: 3-February 09 From: Toronto Member No.: 10,018 Region Association: None |
I paid $6750 for my 3.2 which had 32,000 kms (a little less than 20k mi.). The engine was complete and came with full harness, DME, all of the sensors etc.
Any I've seen up here for under $5k are 100k+ engines. And the parts for these are not cheap when you start replacing things like injectors (around $400 ea.) fuel rails/lines on the engine and so on. It may or may not surprise you that the 3.2 engine already has NLA components . . . (IMG:style_emoticons/default/dry.gif) |
avidfanjpl |
Jun 29 2011, 05:35 PM
914 Hemophiliac Group: Members Posts: 720 Joined: 6-April 10 From: Bear, Delaware Member No.: 11,566 Region Association: MidAtlantic Region |
I have Thomases 2.2L and it has cost me 500 on top of the purchase price to get the Zenith's redone.
I will eventually punch it out to a larger size, but getting it running is the first priority. I think I am like you. I need a big motor and a BIG push. I have had nothing but 2.0L Type IV's and I have a 97 Infiniti G35, and it hauls ass in 0-60. 5.4 seconds is the published speed. I think it is faster. I think you can do a larger aircooled 6 for 6-7K minimum, but everyone else here is right, double that number you pay for the engine to get it into a 914 properly. I had a 6 conversion that I sold overseas, and it was 6K, and I knew I needed another 10K to make it right. I punted and sold it, and got the car Thomas built. I am just finishing The Dark Knight, and it is about 5K just to make it an AX car. I am not going to do high speed events. Too much fiberglass and I am not fond of cages. Just want a go kart with nothing but cones to dodge. Good luck, and do not lose heart! Do what you say you will, and although we all know someone on here that did a conversion, very few discount the experience. I am thrilled just to have a 914 that has a 6 stuffed in it. We do need to count our blessings in aircooled terms. (IMG:style_emoticons/default/pray.gif) John |
Elliot Cannon |
Jun 29 2011, 08:57 PM
(IMG:style_emoticons/default/WTF.gif) Everyone wants a sweet deal but no one wants this one. Go figure? (IMG:style_emoticons/default/confused24.gif) That's OK though. Till I sell it I still get to drive it every week. (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/driving.gif)
John |
Here is what I did to do mine on the cheap......
I started making parts. I made engine sheet metal. Sold maybe 7 sets. I made distributor side block off plates. Sold 20+ or more. I made engine mounts. Sold 5-6 of those. I also sold off my unused parts to offset the costs of other parts like: Oil Tank Headers Flywheel/clutch I made other parts and scoured the internet for bits and pieces. (Pelican was a good source for 911 front ends, brakes, rear hubs, e-brake conversion parts, and other bits) I also sold off the stock 911 3.2 exhaust and the stock 3.2 engine sheet metal. (Pelican is also a good place to sell off parts you no longer need) I paid $6500 for a good solid 3.2 with a 90 day warranty from a salvage yard. It was complete with harnesses, tach, fuel pump, fuel lines, and I had them throw in some other good parts (coarse splined trans output flanges, etc.) I did all my own work and I have a tally sheet that says that after buying and selling parts my installed 3.2 cost just under $4k. I started my conversion in February 06' and was driving it in June 06'. |
John |
Jun 29 2011, 09:03 PM
would you stick with the 901 or need to convert to a 915? I'm staying with the 901 with my 3.0L. That's about its limit I tend to dis-agree. I've been running a stock 901 behind my 3.6L for several years now. So far, no problems at all. (IMG:style_emoticons/default/bye1.gif) I brought this up in another thread, and they really didn't want to hear it....... |
rktmn247 |
Jun 29 2011, 10:46 PM
Irish Green with GT envy! Group: Members Posts: 347 Joined: 18-August 05 From: Mililani, HI Member No.: 4,612 Region Association: None |
(IMG:style_emoticons/default/WTF.gif) Everyone wants a sweet deal but no one wants this one. Go figure? (IMG:style_emoticons/default/confused24.gif) That's OK though. Till I sell it I still get to drive it every week. (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/driving.gif) For me it is not a question of want. I just don't have the funds. I love that car! You are a lucky man and I think the next owner will be also. |
brant |
Jun 30 2011, 06:23 AM
you'd be a lot safer planning on 10 for the conversion process
I know trekkor was convinced that he could do it for 4k I argued with him during the process. he ended up re-doing much of his work remember his motor mount broke twice and most of his other "rigged" attempts ended up braking also. so I still don't think its a 4K job as I told him at the time. I think he dropped many thousands more after he got the $4,000 version running and was faced with all of the cut corners. Plus the cheap oil thanks and 1500 motors have all gone away since that time. brant |
Lo-Fi Version | Time is now: 11th May 2024 - 07:19 AM |
