Fuel Grade Trunk sticker source |
barada |
Jun 29 2011, 08:03 PM
Member Group: Members Posts: 257 Joined: 5-October 08 From: Atlanta Member No.: 9,613 Region Association: None |
Does anyone make the fuel sticker that goes on the passenger wheel well? Not knowing it was even there as I was stripping my paint I went through mine. I could live with it, but would replace if available. Here is a pic of what I am talking about. Also, is the Vin suppose to be raw metal right there? If it is is it just cleared over?My car had been painted twice and I would like for that to be correct. Thanks Phillip |
Tom_T |
Jun 29 2011, 10:18 PM
Phillip,
AA sells a repro fuel grade sticker for a few bucks. The VIN stamping on the wheel housing top was taped off & left raw metal at the factory. Later DAPO repaints cover them if it's too much trouble to stick tape, or don't know to do so. I use a swipe of WD40 to keep it from rusting over. Clear coat enamel will do the same I suppose. FYI - Acetone & a soft touch with a soft rag & Q-tips is the best way to lift paint off of the stickers, plates & labels. Let it set after a first swipe of acetone with a Q-tip, let it bubble up some & then work gently to get the paint but not the label/sticker. I was able to uncover my original factory VIN sticker on the L-R door jamb from 4 oversprays that way, with very little damage to the original sticker. |
barada |
Jun 30 2011, 06:30 AM
Phillip, AA sells a repro fuel grade sticker for a few bucks. The VIN stamping on the wheel housing top was taped off & left raw metal at the factory. Later DAPO repaints cover them if it's too much trouble to stick tape, or don't know to do so. I use a swipe of WD40 to keep it from rusting over. Clear coat enamel will do the same I suppose. FYI - Acetone & a soft touch with a soft rag & Q-tips is the best way to lift paint off of the stickers, plates & labels. Let it set after a first swipe of acetone with a Q-tip, let it bubble up some & then work gently to get the paint but not the label/sticker. I was able to uncover my original factory VIN sticker on the L-R door jamb from 4 oversprays that way, with very little damage to the original sticker. Thanks Tom, I just flat out was not aware it was there, I was just skimming the area and nicked it, after I noticed it I did remove the paint with some thinner. Actually I was able to lift my Vin sticker off the door jamb by heating it up and slowly pulling it up. I plan on regluing it back when it is painted. |
Lo-Fi Version | Time is now: 20th May 2024 - 10:30 AM |
