Newbie Question of the Day: Conversions and Flywheels |
RiqueMar |
Jun 30 2011, 06:19 PM
Enrique Allen Mar Group: Members Posts: 2,169 Joined: 28-August 08 From: San Diego, CA Member No.: 9,478 Region Association: Southern California |
Ok, did a search but just making sure. When doing a /6 conversion (mine is a 77' 'S' Engine) and sticking with the 901 transmission, I need to change the Flywheel, correct?
I'm all ready to go, but I believe I have the wrong flywheel (mine has the ring gear separate). |
rascobo |
Jun 30 2011, 08:27 PM
Member Group: Members Posts: 203 Joined: 26-July 07 From: Portland,OR. Member No.: 7,948 Region Association: Pacific Northwest |
I don't think it matters, as You can use a 911 starter on a 914 four. If You'd like a definitive answer, contact Kennedy Engineered Products.
(IMG:style_emoticons/default/beer3.gif) |
moparrob |
Jun 30 2011, 11:43 PM
Senior Member Group: Members Posts: 646 Joined: 27-April 10 From: Los Angeles Member No.: 11,663 Region Association: None |
You have two options with a 9 bolt flywheel. You can either buy the new conversion ring gear or you can buy the new one piece flywheel from Kennedy. Call them, they're very helpful.
Jul 1 2011, 12:29 AM
A 77 engine would still have a six-bolt flywheel. But it's the one that mates with the 915 transmission, not with the 901 style that is found in our cars.
Get a flywheel from a ~1969 911T. Or from a 914-6. --DD |
pcar916 |
Jul 1 2011, 08:10 AM
Yes, because regardless, you'll want to use a 225mm clutch package. I've used the same 914 style clutch (push-type) for both the 2.7L and 3.6L engines.
But with both I used Sachs "Sport" parts (bigger springs in the pressure plate). For some reason I didn't write down the part numbers. Somebody else know them? The 3.6L uses the same clutch and pressure plate, but a different (6.75lb) flywheel with a speed sensor ring for the DME. Good luck! |
brant |
Jul 1 2011, 08:13 AM
914 Wizard Group: Members Posts: 11,624 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
you need a 2.0/6 flywheel
or a conversion (replica of the same) |
Matt Romanowski |
Jul 1 2011, 08:25 AM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
Call Kennedy and they will help you out.
RiqueMar |
Jul 1 2011, 08:37 AM
GeorgeRud |
Jul 1 2011, 08:38 AM
If you're interested, I have one of those conversion flywheels that I used on my conversion before switching to a 915 transmission. Bolts right onto the 911 engine and fits the 914 transmission, though you do have to make new marks for TDC and 35 BTDC (at least if you're using a 2.7 engine).
If you can't find one locally and need it, let me know. |
RiqueMar |
Jul 1 2011, 08:46 AM
If you're interested, I have one of those conversion flywheels that I used on my conversion before switching to a 915 transmission. Bolts right onto the 911 engine and fits the 914 transmission, though you do have to make new marks for TDC and 35 BTDC (at least if you're using a 2.7 engine). If you can't find one locally and need it, let me know. Geaorge, thanks, you have a PM |
jm993rs |
Feb 8 2012, 05:48 AM
Member Group: Members Posts: 68 Joined: 29-August 11 From: Mallorca Member No.: 13,498 Region Association: None |
Now for my conversion I'm in the same doubst point !!!
I have one 2.4 E with perfect flywheel on 225, and I have one gearbox of 914-4 with the complet cluch. And only found one flywheel of second hand 901. Have the engine starter I have is of the 914-4. For this parts still not have hurry because the car is a little late in the body transformation, but I search and prepair and buy parts for when need. One day I read is possible mount 914-4 cluch on a 2.7 flywheel with a littlel modification on a pressure plate cluch but now do not know where I read !!!! anybody know something ????????? (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/screwy.gif) |
SLITS |
Feb 8 2012, 07:55 AM
Now for my conversion I'm in the same doubst point !!! I have one 2.4 E with perfect flywheel on 225, and I have one gearbox of 914-4 with the complet cluch. And only found one flywheel of second hand 901. Have the engine starter I have is of the 914-4. For this parts still not have hurry because the car is a little late in the body transformation, but I search and prepair and buy parts for when need. One day I read is possible mount 914-4 cluch on a 2.7 flywheel with a littlel modification on a pressure plate cluch but now do not know where I read !!!! anybody know something ????????? (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/screwy.gif) The early 911 flywheel (901 flywheel) uses the same clutch assembly as the /4s. It did have heavier springs in the pressure plate and used 6 springs in the driven plate (clutch disk). It is the 215 mm clutch assembly Currently, there is no difference between the early /6 clutch assembly and the /4 assembly. From 1970 & up, the 911s use a flat flywheel and a 225 mm clutch assembly which will not work with the /4 transmission UNLESS you obtain a '70 - '71 ONLY 911/901 transmission. |
Lo-Fi Version | Time is now: 17th May 2024 - 05:21 PM |
