914R build thread revisited, Latest transformation has commenced |
campbellcj |
Jul 2 2011, 04:23 PM
I can't Re Member Group: Members Posts: 4,543 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
Some of you may have seen my earlier build thread on the 914club site. In a nutshell I have a 73 2.0 that I converted to a six in 2003. It's now heavily modified and race-prepped, powered by a stout 2.7 twin-plug engine.
The car currently weighs 1988lbs without fuel or driver; my POC minimum class weight with gas and driver is 2209lbs. It's still narrow-bodied and I am running 16x7 Fuchs with 205/45 Hoosiers. As you might guess, the car is significantly grip-limited and traction-limited in the rear especially. It basically tears the tread off R6's within 6 run sessions or so. Here is its current state: (IMG:http://www.914world.com/bbs2/uploads_offsite/farm6.static.flickr.com-21-1309645382.1.jpg) 914R at Streets of Willow by cjcam, on Flickr (IMG:http://www.914world.com/bbs2/uploads_offsite/farm6.static.flickr.com-21-1309645383.2.jpg) 914R at Willow Springs by cjcam, on Flickr I just dropped it off at a local shop, about to dive into: - Tangerine Racing steel flares, front/rear - Sheridan 6" f/g rear spoiler - Rollcage triangulation to suspension pickups - Possibly other chassis bracing - GT headlight lifts or remove lights completely - Repaint car (TBD how extensively) - RSR finish Fuchs 16x8's up front, 9's in rear - New graphics/decals One upcoming decision is whether to keep the sail vinyl or go body color without vinyl. I've always liked the factory vinyl and bright trim look but could go either way on this. The work could start as soon as Tuesday and I'll post updates and pics as I get them. This is not going to be a CW rotisserie sort of project since it's a race car, so progress should happen quickly and I plan to run the POC Laguna Seca event towards the end of August. Cheers, |
J P Stein |
Aug 29 2011, 05:59 AM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
Lookin' good, Chris.
Eye balling the front flares would seem to indicate that bigger front wheels would fit......I was able to get 10 X 16 under my hand hammered fenders but they were a bridge too far. I went back to 8 inchers due to scrub raduis problems (you would't like it).....9s *might* have worked. |
campbellcj |
Aug 29 2011, 09:56 PM
Lookin' good, Chris. Eye balling the front flares would seem to indicate that bigger front wheels would fit......I was able to get 10 X 16 under my hand hammered fenders but they were a bridge too far. I went back to 8 inchers due to scrub raduis problems (you would't like it).....9s *might* have worked. Thanks JP. Since POC rules look at wheel width not tire size, and I already have two sets of 8's and 9's I will stick with that for now. However, the pic shows 225 front and 245 rear which I wanted to start with to play it safe on clearance. I do think there is clearance to run 245 front and 275 rear (Hoosier R6) as I'd hoped, and if measurements back that up I will try that combination next. The car should be home within days and at the track on 9/11 if the stars align in my favor. |
Lo-Fi Version | Time is now: 6th May 2024 - 01:32 PM |
