campbellcj
Jul 2 2011, 04:23 PM
Some of you may have seen my earlier build thread on the 914club site. In a nutshell I have a 73 2.0 that I converted to a six in 2003. It's now heavily modified and race-prepped, powered by a stout 2.7 twin-plug engine.
The car currently weighs 1988lbs without fuel or driver; my POC minimum class weight with gas and driver is 2209lbs. It's still narrow-bodied and I am running 16x7 Fuchs with 205/45 Hoosiers. As you might guess, the car is significantly grip-limited and traction-limited in the rear especially. It basically tears the tread off R6's within 6 run sessions or so.
Here is its current state:
914R at Streets of Willow by
cjcam, on Flickr
914R at Willow Springs by
cjcam, on Flickr
I just dropped it off at a local shop, about to dive into:
- Tangerine Racing steel flares, front/rear
- Sheridan 6" f/g rear spoiler
- Rollcage triangulation to suspension pickups
- Possibly other chassis bracing
- GT headlight lifts or remove lights completely
- Repaint car (TBD how extensively)
- RSR finish Fuchs 16x8's up front, 9's in rear
- New graphics/decals
One upcoming decision is whether to keep the sail vinyl or go body color without vinyl. I've always liked the factory vinyl and bright trim look but could go either way on this.
The work could start as soon as Tuesday and I'll post updates and pics as I get them. This is not going to be a CW rotisserie sort of project since it's a race car, so progress should happen quickly and I plan to run the POC Laguna Seca event towards the end of August.
Cheers,
brant
Jul 2 2011, 04:27 PM
very cool Chris
Mike Bellis
Jul 2 2011, 04:48 PM
Remove the vinyl. You will save 8oz of weight. I'll be watching!
campbellcj
Jul 2 2011, 05:30 PM
QUOTE(kg6dxn @ Jul 2 2011, 03:48 PM)
LOL, good point, I will be trying to keep the weight down as obviously the bigger wheels/tires will add significant weight, as will any cage tubes or chassis braces added.
Ditching the headlights, motors and turn signal buckets will help a bit. I'm also probably going to swap my one late door (there must be a PO story behind that) for an early door.
There's not much else that can be removed short of drilling or cutting-out metal such as the rear trunk floor or targa hoop, and I don't want to do that right now.
campbellcj
Jul 8 2011, 10:08 PM
So a couple of you have already discovered that my car is at Kundensport in Camarillo for the body/paint work. I will be posting pics as available.
Here are the wheels I've been hanging onto until I had flares to stuff them under. I will be putting Hoosier R6's on them.
16x8 and 16x9 Fuchs, RSR finish by
cjcam, on Flickr
16x8 & 9 Remotec alloys (German) by
cjcam, on Flickr
URY914
Jul 9 2011, 06:19 AM
You could just paint the sail panels like I did on mine. I added a 1/4" chrome tape to act as the trim. From 10' you can't tell it's paint.
tscrihfield
Jul 9 2011, 07:21 AM
I remember when I was first building I ran into your flikr account photos and was in love with your ride! But I must ask why steel flares on a race car? Have you seen the full FG quarters & fenders that QRS fiberglass has? They are already flared and with chassis stiffening it would be worth it for weight reduction. I think you would lose something like 130-150#s... None the less I anticipate your renovations you have a very nice car!
Jul 9 2011, 08:11 AM
QUOTE(tscrihfield @ Jul 9 2011, 09:21 AM)
4 steel GT flares weigh around 20-25#S so 130-150# savings, even from the whole panel, is probably really optimistic.
Plus, you are removing metal when you add flares so the total weight gain is less than the flares weigh. It's the bigger wheels and tires that add some weight.
J P Stein
Jul 9 2011, 09:56 AM
The Fuch are light.....a bathroom scale will show that the 8 X 15 inchers are around 12 lbs ea. Those other things look heavy. In my experience to get a 16 incher that approaches those weights you need to go to a 3 piece wheel with a spun rim. My 10 X 16s weighed 11 lbs each but they are delicate....as tire mounters have found out.
Tis a slippery slope you are contemplating. Personally I go with 15 inch wheels, 8 inch in front & 10 inch in back. 225 X 45 & 275 X 35 tires they would keep the ride height down. The standard flares in back won't accommodate those rears but you have the HP to over power even those. OK, so I set up cars to suit available tires.....I've been on that slope.
campbellcj
Jul 9 2011, 10:04 AM
With the Tangerine Racing flares, you are not adding or removing metal so there should be no drastic effect on weight. I went this route because I like the 'stealth' factory-like appearance of them, since they are reworked original steel vs. something obviously tacked-on. With this car I decided I did not want to cut-off the majority of the body and do something like a Sheridan kit or other total body replacement; although, I did think seriously about that.
campbellcj
Jul 9 2011, 10:07 AM
JP - those Remotec wheels are nearly identical in weight to the same-sized Fuchs, believe it or not! I can no longer use smaller than 16" wheels due to the suspension mods (strut spindles) up front; also the DOT tire choices are rapidly dwindling in 15" and are still a little better in 16".
J P Stein
Jul 9 2011, 05:52 PM
OK, I thought you were talking race tires but your right, the available DOT tire selection sucks. I run 19mm raised spindles with just a few mods to clear the inside of the wheel....tis a near thing. Bigger wheels & tires are heavier (& taller) than the 15s. I guess it is whatever floats your boat.
tscrihfield
Jul 9 2011, 11:09 PM
Understood! I am a firm believer in you like what you like. Also, had no idea you were just working the original fenders... I am in even more anticipation to see it now!
And I know what you mean about the wheel size, I can't go below 17inches because how far I lowered my spindles!
QUOTE(campbellcj @ Jul 9 2011, 12:04 PM)
J P Stein
Jul 10 2011, 08:48 AM
In my race car building days I was obsessed with several things among which were low over all weight, low unsprung weight, & low CG of the whole car.
I jumped through a lot of hoops to get there without screwing up the the camber, toe curves....& bumpsteer, of course from the stock settings......I ain't smart enough to re-engineer the suspension to a better point than Porsche did. Due to some professional help with shock valving (& shitcanning the rubber bushings) & some fairly radical stiffening of the chassis (lots of room for improvement there) I feel I was reasonably successful. Any advice I offer is based on those obsessions plus the absolute need to have fairly compliant suspension to handle the bumps of several AX venues.
Reading your post, Chris, would lead me to believe your car is no longer going to be street legal (no headlights?). Your need for DOT legal rubber confuses me. Are you running some kinda spec series rubber that calls for some oddball wear rating? Hoosier makes DOT legal R&A6s and the available rubber is as good (better IMO) in 15 inch as 16 inch.
BTW, tscrihfield, *lowering* ones spindles is counter productive and would not effect wheel size.
Terminology counts.
campbellcj
Jul 10 2011, 09:38 AM
JP, you are correct, classification rules are the only reason I use DOT tires. Race tires would bump me another class with POC. It's a points-based system but I'm already topped-out in my current class once I add the wider wheels. I would love to try slicks sometime though.
Also, I have to run a minimum car weight and am already right on the line there.
FWIW many if not most of the competitive 911 guys down here have gone to 17's. I'm pretty sure that is for wheel selection as well as tires.
J P Stein
Jul 10 2011, 09:53 AM
A & R6s are race rubber I was talking about....not slicks. Are these
https://www.hoosiertire.com/rrtire.htm legal? Click on "specs".
campbellcj
Jul 10 2011, 10:00 AM
Yes, I've been using the R6 and predecessors for years. I can use any DOT tire...non-DOT slicks are where I can't tread for now (sorry).
Still can't go down to 15's without raising the spindles back up...
tscrihfield
Jul 10 2011, 10:19 AM
QUOTE(J P Stein @ Jul 10 2011, 10:48 AM)
Terminology counts.
I guess the proper way to say it is "raising" the spindles to drop the car...
You got me on that one! I was a little tired when I posted last night...
But I honestly can't because I tried to install my 16" wheels and they hit the lower control arm due to spindle location. My 17" wheels have room but the 16s are a little too small...
tscrihfield
Jul 10 2011, 10:23 AM
QUOTE(campbellcj @ Jul 10 2011, 12:00 PM)
Better watch how you state it JP will get ya!
I know you mean lower your spindles to original location....
J P Stein
Jul 10 2011, 04:48 PM
Chris & I go way back so know what he means to say.
BTW, Chris, is Sienfeld's collection still across the street?
campbellcj
Jul 10 2011, 08:54 PM
Ok, lowering the spindles back up. How's that.
Yup the collection is still there, at least the west coast portion. With that plus the VW-Audi design center next door, there are lots of cool cars to drool over.
campbellcj
Jul 16 2011, 10:48 PM
The bodywork is officially underway! I dropped-off the larger Fuchs with fresh Hoosiers today, for test-fitting purposes, as well as spoilers etc.. The front Getty lid has been aligned and filled a tad, replacement door fitted, windshield and sail trim removed, and other stuff is also starting to come off. Next week the actual cutting/welding/sanding should commence.
J P Stein
Jul 17 2011, 08:17 AM
Your pretty car is gonna look like hammered shit ....just for a while, hopefully.
Is your "tad" the same as mine.....about this much?
tavoman27
Jul 18 2011, 12:31 AM
QUOTE(campbellcj @ Jul 16 2011, 09:48 PM)
Click to view attachmentDo not worry about your car, Galen is one of the best builders out there... He actually build my 914 and never had a problem... I'm working on my own version of a 914 RS... so I will put fiber glass pieces to drop 200lbs, will keep 2.0L FI but will try to get an exhaust system to get 10hp more... Galen rebuild the engine years ago with some nice tricks and installed a Carrera front end with a 914-6 rear plus all the suspension tricks that he knows about... the car handles great, I run super light Fuchs that are 15x7 all around... I will send you some pics of my build if interested... when you see Galen just tell him you came across Bill Boyd 914... he will go on from there! later and good luck and hope to see you at the next POC in Fontana.
campbellcj
Jul 25 2011, 12:59 PM
tavoman27, to clarify, Galen has done a bunch of suspension and brake work on this car lately but now it is at a different shop -- Kundensport -- for the body & paint work.
Here is the latest update as of this morning. The dis-assembly and fitting work is well underway (engine, seats, etc. still need to come out.).
Ed is concerned about the fit & finish of the rear flares but he is going to work on them some more before we consider "Plan B". The fronts are great. Nothing has been cut or welded yet, this is just test-fitting so far.
JP, here is some "hammered shit" for ya. It will get a lot worse before it gets better...
Andyrew
Jul 25 2011, 01:34 PM
Chris, did your bodyman make those flares? Very interesting how he decided to form them off the body.
They look almost like Tangerine Racing flares.
campbellcj
Jul 25 2011, 01:48 PM
QUOTE(Andyrew @ Jul 25 2011, 12:34 PM)
That's cuz they are...should look sweet and last forever once finished, but doing this kind of metal work is not nearly as quick and painless as bonding or bolting-on some 'glass...
AZ914
I think he said he was doing the Tangerine flares earlier up in the thread.
tscrihfield
Jul 25 2011, 03:19 PM
Chris,
Your car is going to look amazing! Cant wait to see this one done! Those flares are really giving your car an added bit of unique!
Cheers to you!
Thomas
campbellcj
Jul 30 2011, 03:31 PM
The flares are on! The right side is nearly paint-ready, the left side (shown) still rough. Clearance is just fine with the 245's on 9's and with the optimum offset wheels, 275's on 9's or even 10's should be doable.
Click to view attachment The below pic of the front is still with the old 205 tire on a 7x16 wheel. I think I can fit 245's up front as well, but for starters I bought 225's to be safe.
campbellcj
Aug 6 2011, 11:07 PM
The car is pretty close to paint now. The flares are installed, smooth as a baby's skin. Also the lids are fine-tuned for nice gaps, rear trunk floor rust repaired, doors prepped. Next week the engine will come out, and some new cage tubes welded-in. Then I suppose paint is next.
The rear flares look cool IMO. It's hard to really get a shot that shows the lines with the car in primer and shop lighting. The lips on the fronts seem a little larger than needed, but I'm sure I will get used to it. (The old 205's are back on the car in this pic.)
914R almost ready for paint by
cjcam, on Flickr
campbellcj
Aug 6 2011, 11:10 PM
BTW, I decided to go without sail panel vinyl. The car has a lot of black trim already.
JRust
Aug 6 2011, 11:30 PM
Love those flares! Really keep the original lines well. Doesn't jump out at you that they are custom. I hope to get those flares someday. Time to start saving I guess
campbellcj
Aug 29 2011, 12:16 AM
More progress. The tub and rollcage are sprayed, woohoo!. The other parts should be done tomorrow, then it goes back together.
The flares are subtle, depending on the angle and lighting. Those are 8's and 9's on the car now. There seems to be room for 9's and 10's, perhaps.
Sorry for the crappy iPhone pic.
914R is painted by
cjcam, on Flickr
nsr-jamie
Aug 29 2011, 05:42 AM
Looks very nice !! Like a stealth 914!! Cool !!
J P Stein
Aug 29 2011, 05:59 AM
Lookin' good, Chris.
Eye balling the front flares would seem to indicate that bigger front wheels would fit......I was able to get 10 X 16 under my hand hammered fenders but they were a bridge too far. I went back to 8 inchers due to scrub raduis problems (you would't like it).....9s *might* have worked.
Cairo94507
Aug 29 2011, 06:24 AM
Beautiful work and car. I look forward to seeing some pictures of the finished product.
Andyrew
Aug 29 2011, 08:17 AM
Looks great!!
JmuRiz
Aug 29 2011, 09:11 AM
Wow, I really love those 'flares' keep the skinny body lines while allowing the larger wheels/tires!
pete-stevers
Aug 29 2011, 09:52 AM
lookin GREAT!!!
abnrdo
Aug 29 2011, 09:56 AM
Very cool!
eric9144
Aug 29 2011, 10:14 AM
campbellcj
Aug 29 2011, 09:56 PM
QUOTE(J P Stein @ Aug 29 2011, 04:59 AM)
Thanks JP. Since POC rules look at wheel width not tire size, and I already have two sets of 8's and 9's I will stick with that for now. However, the pic shows 225 front and 245 rear which I wanted to start with to play it safe on clearance.
I do think there is clearance to run 245 front and 275 rear (Hoosier R6) as I'd hoped, and if measurements back that up I will try that combination next.
The car should be home within days and at the track on 9/11 if the stars align in my favor.
campbellcj
Aug 29 2011, 10:00 PM
Another tire option would be a 'square' setup with 245's or 255's all around.
0396
Aug 29 2011, 10:10 PM
Very nice
jeff
Aug 30 2011, 06:06 PM
Looks Fantastic! Ed can certainly work magic with a Spray Gun!
campbellcj
Sep 3 2011, 09:58 AM
Woohoo, the car will be home within a couple of days! It's in final trim and detailing stage now. Not sure I will have time to visit for progress pics today. Due to hit the track on 9/11 (next Sunday)!
siverson
Sep 3 2011, 09:38 PM
Looks awesome! (don't crash!
-Steve
campbellcj
Sep 3 2011, 09:55 PM
QUOTE(siverson @ Sep 3 2011, 08:38 PM)
-Steve
Doh! I wish you hadn't mentioned that. I will be at Streets next weekend and will have to take it a bit easy at first to get used to the changes...
siverson
Sep 3 2011, 09:57 PM
Remember, you can go pretty much flat out through the small "chicane" on the back straight! (most of the time)
-Steve
