Well I finally updated my build notes and here they are. It had been a few years so I may have missed a mod or two. I hope to get the car dynoed and weighed in a few weeks.
As you can see, the car is completely 100% stock.
Engine, Transmission and Fuel System:
• 2.7 rebuilt and race-prepped by Galen Bieker (December 2013) on early 7R case (#6342207); line-bored; timeserted; oil mods; 930 oil pump; STD/STD crank; 90mm Mahle Nikasil cylinders; 90mm 10.5:1 C/R JE Pistons
• Doherty DC42 "mod S" cams; ports 38mm intake/34mm exhaust flowed; new valves and guides; polished and rebushed factory rods; new OE rockers; ARP fasteners; AASCO racing valve springs and titanium retainers
• JB Racing magnetically-triggered twin-plug distributor
• Dual MSD-6AL CD’s and matching coils
• Series 900 911R/RSR style raw fiberglass shroud and air blockoff
• Dual Weber 40IDT3C carbs rebuilt and modified to 46mm by Bieker Engineering; PMO tall manifolds; K&N filters with flat tops (watershields in spares); PMO billet fuel bars; solid metal lines thru tunnel and braided AN-6 lines elsewhere
• Patrick Motorsports / Fuel Safe cell; Canton filter; Holley “Red” fuel pump
• Carrera pressure-fed chain tensioners
• Turbo lower valve covers modified for twin-plug
• Ottos short-geared 901 5-speed gearbox (A,GA,Ka,Q,V)
904 mainshaft and GA 2nd gear; billet intermediate plate; Quaiffe TB differential; replaced sliders, synchros, bearings etc.
• Sachs aluminum race pressure plate; Clutch Masters 6-puck race clutch disc
• Wevo semi-solid alloy transmission mounts
• MazdaComp (Mazdaspeed Motorsports) 22"x6.5"x2" front oil cooler (p/n 1058-78-180); custom alum. shrouding; Canton breather; Troutman oil thermostat; NOS factory oil tank; braided AN-12 lines
• Jet-Hot ceramic coated Bursch 1-5/8" header
• European Racing Headers cookie-cutter megaphones (track-only)
• M&K Exhaust “R” 321 stainless 2-in/2-out sport muffler (street/track)
• Triad quiet version 2-in/2-out muffler (street)
• Rich Johnson reproduction 914-6 sheet metal, modified for twin-plug
• Vellios bulkhead engine mount
• Mechanical work and race-prep by Ottos, Werks II Motorsports, and TLG Auto
Exterior:
• "Phoenix Red", code L32K
• Tangerine Racing Products custom steel flares made from factory metal fenders
• Flares, rollcage mods and paint by Ed Palmer at Kundensport
• Additional body/paint work by John Esposito
• Early doors with glass, regulators and locks removed
• Getty Design 914-6 GT replica fiberglass lids (front/rear) with balsa reinforcements
• Mittelmotor GT hood pin kit
• GT Racing fiberglass bumpers (front and rear) w/ dzus fasteners
• Fiberglass front spoilers (LE, medium, and Sheridan) with oil and brake cooling inlets
• Fiberglass rear spoiler (Sheridan)
• Rennspeed lightweight fiberglass targa top "skin" w/ dzus fasteners
• 914-6/GT-style engine lid, lightened and removable with captive pin fasteners
• Lexan rear window
• New windshield (June 2014)
• Smart Racing Products windshield hold-down tabs
• Factory 914 mirror
• Many rubber seals replaced (although a lot are now removed)
Interior:
• Stripped for racing; sound deadening tar removed; POR-15 treated
• Tony Colicchio (TC Design) custom welded 10-point roll-cage
(1.5" x .125" DOM mild-steel tubing, SCCA/PCA/POC legal)
• Cobra Suzuka kevlar composite FIA-approved race seats and brackets
• Schroth Profi-III 5-point camlock harnesses
• Personal "Fittipaldi" 350mm steering wheel
• Tekniq Autosport "Snap-Off" removable steering hub
• RennShift high-performance shifter assembly
• Momo billet aluminum shift knob
• Ottos rebuilt pedal cluster; bronze bushings; reinforced throttle bellcrank
• 9R Parts laser cut aluminum pedal/footrest boards
• AJ-USA drilled aluminum pedal set
• Rennline drilled aluminum dead pedal
• Longacre 14" convex mirror
• Spa FireFighter 4L AFFF electrical fire system
• Ultra light 1/16" ABS and aluminum door panels
• Interior metal surfaces painted with POR-15
Suspension, Wheels/Tires and Brakes:
• 15x8” and 15x9” Braid RSR-finish Fuchs replicas with Hoosier R80 Radial Slicks
• 15X8” Fuchs and 15x9” Braid black/anodized wheels with Hoosier R6 DOT-R radials
• Sway-A-Way 22mm tubular front torsion bars
• Bilstein 911SC front struts, raised spindles, decambered, custom valving
• Custom monoball front strut tops/camber plates
• Smart Racing Products No. 27 front swaybar
• Meuller Engineering front A-arm needle bearings
• Widened front track via H&R spacers
• Elephant Racing polybronze rear bushings
• Hypercoil 350lb 2.5x10” rear springs and Coleman threaded coil-over collars
• Bilstein Sport rear shocks (F4-B46-0179-H003) with custom valving
• Factory 16mm rear swaybar; restored, new bushings
• GT chassis stiffening kit; boxed rear trailing arms
• Recent OE axles and CV's
• Repro 914-6 stub axles and early 911 hubs
• Lowered and corner balanced
• 911 Carrera "A" front calipers; vented Carrera rotors; Pagid Orange pads
• 911 Carrera "M" rear calipers; vented Carrera rotors; Pagid Orange pads
• 19mm (911) master cylinder
• Goodrich DOT stainless-steel brake lines
• Smart Racing Products cooling backing plates and air diverters
• Endless racing brake fluid
Electrical
• Racepak G2X data acquisition and digital dash
• AMB TranX260 hardwired transponder #1957265
• Hella H4 euro headlights, PIAA Superwhite bulbs
• Sergio Meza euro parking/turn-signal kit; Hella euro lenses
• VDO speedometer rebuilt by North Hollywood Speedometer
• VDO early 911 tachometer modified to 10K face and updated circuitboard by NH Speedo
• Custom quad-gauge (oil temp, pressure, fuel, volt) by Mark Surel / NewVintageUSA
• Bosch 911 Carrera (SR68X) starter
• Inline blower fan and ducting from cowl to cockpit for ventilation
• OMP 3-pole electrical kill switch
• Odyssey PC680 lightweight dry-cell battery; aluminum bracket
• Custom stock-replacement ATO fuse box by Mark Bland
• GoPro Hero2 HD in-car camera
• FIAMM dual-tone horns (lighter and louder than stock Hella)
Miscellaneous Stuff
• Smog exempt in California
• Ventilation system, sound deadening tar, carpets and other weight items removed
