914R build thread revisited, Latest transformation has commenced |
campbellcj |
Jul 2 2011, 04:23 PM
I can't Re Member Group: Members Posts: 4,543 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
Some of you may have seen my earlier build thread on the 914club site. In a nutshell I have a 73 2.0 that I converted to a six in 2003. It's now heavily modified and race-prepped, powered by a stout 2.7 twin-plug engine.
The car currently weighs 1988lbs without fuel or driver; my POC minimum class weight with gas and driver is 2209lbs. It's still narrow-bodied and I am running 16x7 Fuchs with 205/45 Hoosiers. As you might guess, the car is significantly grip-limited and traction-limited in the rear especially. It basically tears the tread off R6's within 6 run sessions or so. Here is its current state: (IMG:http://www.914world.com/bbs2/uploads_offsite/farm6.static.flickr.com-21-1309645382.1.jpg) 914R at Streets of Willow by cjcam, on Flickr (IMG:http://www.914world.com/bbs2/uploads_offsite/farm6.static.flickr.com-21-1309645383.2.jpg) 914R at Willow Springs by cjcam, on Flickr I just dropped it off at a local shop, about to dive into: - Tangerine Racing steel flares, front/rear - Sheridan 6" f/g rear spoiler - Rollcage triangulation to suspension pickups - Possibly other chassis bracing - GT headlight lifts or remove lights completely - Repaint car (TBD how extensively) - RSR finish Fuchs 16x8's up front, 9's in rear - New graphics/decals One upcoming decision is whether to keep the sail vinyl or go body color without vinyl. I've always liked the factory vinyl and bright trim look but could go either way on this. The work could start as soon as Tuesday and I'll post updates and pics as I get them. This is not going to be a CW rotisserie sort of project since it's a race car, so progress should happen quickly and I plan to run the POC Laguna Seca event towards the end of August. Cheers, |
campbellcj |
Apr 1 2012, 09:34 AM
Finally! After months of frustration I finally have my hands on the 92mm (2.8) P&C's to put my engine back together. Apparently Mahle only makes the less common stuff in batches every once in a while and once they're gone you are SOL until they decide to make more. They weren't planning to make any more 92mm stuff until this summer at the soonest.
I probably will not use these pistons as they're "only" 10.5:1 C/R and I want to go up to 12.5:1 or so ideally; getting pistons should not be a problem as it's the barrels that are made of unobtainium. I will probably save these pistons in case someday I want to put the car back to a more streetable configuration. I also have one of these on the way. It's not an absolute necessity but is cool, and my current "S" red shroud is a bit damaged. There are still some kinks with the bodywork to figure-out as well. The rear flares are too small to fit the optimal tires and the fronts have some strange geometry/clearance problem I don't fully understand yet (going to see in person this week). The solution to that may be going back down to 15" wheels/tires which would require re-modifying or changing the struts. |
Lo-Fi Version | Time is now: 6th May 2024 - 05:23 AM |
