forgive me, painted my car with a brush |
machina |
Jun 19 2004, 01:19 PM
just the lower part of the engine bay.
looks fine from a standing position. have a new respect for painters. dr |
Joe Bob |
Jun 19 2004, 01:44 PM
Painted a boat once with a brush...desert camoflage, called it the Ramboat..... (IMG:style_emoticons/default/beer.gif)
We had been drinking..... (IMG:style_emoticons/default/confused24.gif) |
i love porsche |
Jun 19 2004, 05:04 PM
Senior Member Group: Members Posts: 1,547 Joined: 6-May 04 From: Nutley, NJ Member No.: 2,030 Region Association: North East States |
ill have to paint some of my engine bay with a brush..because im using a special kind of thick paint with a heavy zinc concentrate that can actually stick to surface rust and stop it from spreading..because i doubt that i can get out 100% of the rust in there
Joseph Mills |
Jun 19 2004, 05:16 PM
on a Sonoma diet now... Group: Members Posts: 1,482 Joined: 29-December 02 From: Oklahoma City, OK Member No.: 39 |
QUOTE(synthesisdv @ Jun 19 2004, 01:19 PM) just the lower part of the engine bay. looks fine from a standing position. have a new respect for painters. well.... (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) |
machina |
Jun 19 2004, 06:11 PM
ok joe,
it was really the area below the line where the tin meets the firewall and the pickup pts etc. the new motor has no tin around it for easy access, only what is needed to cool. the car was yellow before and so was all these areas. just wanted it to look decent with the new motor going in. I'm no painter. dr Attached image(s) |
Joseph Mills |
Jun 19 2004, 08:22 PM
Looks good Dave.
Actually I'm considering painting my engine bay gray and powder coating the two large engine shroud tin pieces gray, just to lighten everything up. My engine bay is black and everything just seems to dissappear. My car body is yellow right now but someday it will be either silver or gray. Something to think about tomorrow while I clean up and tear open my tranny. Yup, since the engine is out, I've decided to open up the tranny and two spares I've been given and look at the possibility of doing a 5th & 3rd gear swap. Help! I've fallen into this "since the engine is out" syndrom and I can't get up. (IMG:style_emoticons/default/wacko.gif) (IMG:style_emoticons/default/laugh.gif) |
machina |
Jun 19 2004, 08:39 PM
my tin is powdercoated with a textured aluminum color. Looks great.
it does help to have things bright in the engine bay. the light reflects better so you can see what your doing wrong. dr |
Joseph Mills |
Jun 19 2004, 08:43 PM
QUOTE(synthesisdv @ Jun 19 2004, 08:39 PM) the light reflects better so you can see what your doing wrong. Hmmm.... maybe I should re-think this. (IMG:style_emoticons/default/laugh.gif) You gotta pic? |
machina |
Jun 19 2004, 08:51 PM
QUOTE(joseph222 @ Jun 19 2004, 10:43 PM) QUOTE(synthesisdv @ Jun 19 2004, 08:39 PM) the light reflects better so you can see what your doing wrong. Hmmm.... maybe I should re-think this. (IMG:style_emoticons/default/laugh.gif) You gotta pic? your on the right track. just don't pick too dark of a grey, keep it lighter. I did the motor bright aluminum for aesthetic reasons aside from the improved visibility. dr Attached thumbnail(s) |
Joseph Mills |
Jun 19 2004, 09:33 PM
I like it. Understated. No flash. All business. Not to mention visibility....
Did you paint the engine core + front & back aluminum covers also? Definitely got me thinkin' (IMG:style_emoticons/default/idea.gif) |
machina |
Jun 20 2004, 07:20 AM
QUOTE(joseph222 @ Jun 19 2004, 11:33 PM) I like it. Understated. No flash. All business. Not to mention visibility.... Did you paint the engine core + front & back aluminum covers also? Definitely got me thinkin' (IMG:style_emoticons/default/idea.gif) the case, intakes, whatever is aluminum is not painted. all the tin, valve covers are powder coated and the blower housing is painted. dr |
thomasotten |
Jun 20 2004, 06:18 PM
Senior Member Group: Members Posts: 1,545 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 |
Arent you worried about your car overheating with all the engine tin cut away? You need to seperate the hot side from the cool side, unless you are makeing a drag car that is only driven in brief spurts.
machina |
Jun 20 2004, 06:33 PM
QUOTE(thomasotten @ Jun 20 2004, 08:18 PM) Arent you worried about your car overheating with all the engine tin cut away? You need to seperate the hot side from the cool side, unless you are makeing a drag car that is only driven in brief spurts. we'll see... almost every 914 racecar I have seen has no tin. I don't plan on doing alot of idling or cruising. We'll either be wide open or in the paddock. dr |
i love porsche |
Jun 20 2004, 08:43 PM
that is one beeeeaauuuutiful engine!
Lo-Fi Version | Time is now: 17th May 2024 - 05:33 PM |
