six conversion engine mounts, which is best |
bhfast |
Jan 13 2003, 04:32 PM
live it loud, balls out Group: Members Posts: 83 Joined: 30-December 02 From: Chandler, AZ/Daytona Beach, FL Member No.: 48 Region Association: Southwest Region |
I have seen several different types of six conv. engine mounts. patrick has 2, the bulk head one that pelican sells, and rich johnson's( i beleive is similar to pelican's) which have you guys used? all input is appreciated.
BH |
Brad Roberts |
Jan 13 2003, 08:11 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
It is designed to be both. I personally bolt them in and then weld them. I'm pretty sure JP did this also on his conversion. The problem with leaving it bolted in: The lower firewall that this would bolt too..is double walled with about an inch gap. You either have to make spacers for it too pinch both walls or you need to drill large enough holes that you can tighten everything against the engine firewall. I personally just used the bolts to hold it in place when I welded mine.
Go here: http://www.all914.com and click on the projects page and look at Brads six conversion. B |
Lo-Fi Version | Time is now: 20th May 2024 - 10:53 PM |
