Smells Like Gas, it's not me... |
schweggy |
Jun 20 2004, 05:59 PM
angry old white guy Group: Members Posts: 43 Joined: 25-September 03 From: Monterey, CA. Member No.: 1,193 |
I noticed that the car is stinking up the garage with gasoline fumes. Happens when the ignition is turned to the "acc" position and the electronics are on as well as when it's been run.
What can cause this and how can I fix it? TIA |
nebreitling |
Jun 20 2004, 07:05 PM
fuel leak. replaced all fuel lines with high-pressure metric line. PLEASE don't run the car until you've replaced them.
also don't forget the lines under the tank. check the condition of the hard lines through the center tunnel. replace if needed. p.s. take the battery out of the car before you start this project. |
RocknRollFrenzy |
Jun 20 2004, 07:19 PM
Member Group: Members Posts: 94 Joined: 3-November 03 From: Santa Cruz, CA Member No.: 1,305 |
(IMG:style_emoticons/default/agree.gif) Did this in my car not too long ago. Be sure to check the short little hoses that run to your injectors (assuming that you still have fuel injection).
Joe Bob |
Jun 20 2004, 07:32 PM
Don't forget the hoses under the fuel tank...prolly older than you are....
Chris H. |
Jun 20 2004, 08:28 PM
Senior Member Group: Members Posts: 4,030 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
QUOTE(nebreitling @ Jun 20 2004, 07:05 PM) PLEASE don't run the car until you've replaced them. . Amen to that. I can't find the shot of the 914 fully engulfed in flames, but this one should give you an idea of what can happen in about 30 seconds or so.... Attached thumbnail(s) |
scotty |
Jun 20 2004, 08:36 PM
The Fun Never Stops Group: Members Posts: 773 Joined: 20-May 03 From: Portland. Oregon (SW) Member No.: 718 Region Association: None |
This one? (IMG:http://members.rennlist.com/914_collectibles/zWRFire01A.jpg)
Jeff Bowlsby keeps all kinds of arcane shots ...here are the \"collectibles\" (I contributed the last fire shot -- not my car!) Has it been hot there? If your tank is vented to the air...maybe that's the cause. It's probably those lines hidden under the fuel tank though |
Chris H. |
Jun 20 2004, 08:37 PM
Yep. That would be it.
schweggy |
Jun 20 2004, 08:57 PM
Well it sounds like I'll be checking and replacing some fuel lines.
Just to clarify... there is no gas leaking anywhere I can see. The odor goes away after an hour or so, but it is fairly strong when the car it put back in the garage. Any suggestions on where to get some replacement lines? I really don't like the flames... bad experience with a lighter and some baked beans. |
iamchappy |
Jun 20 2004, 09:30 PM
I too have the dreaded gas vapor problem, I think that it is coming from the gas cap, over the years I think the seals dry up , I know there are no leaks anywhere ( Ive checked over it a million times) and all my fuel lines are new. If you find the answer let us know.
jim912928 |
Jun 20 2004, 09:35 PM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
replace all the rubber fuel lines (up front and the engine bay). I found mine in the front (have a 75 so the filter and pump are up there under the tank) were soaking through..not enough to drip but enough to saturate the hoses so if you grabbed them they were wet.
There is a good diagram for all fuel lines on the pelican sight (with lengths and diameters). I then ordered everything from pelican. It only took an afternoon to replace them all. They are probably old! Replace them all! |
Jun 21 2004, 01:15 AM
QUOTE(schweggy @ Jun 20 2004, 07:57 PM) Just to clarify... there is no gas leaking anywhere I can see. The odor goes away after an hour or so, but it is fairly strong when the car it put back in the garage. i had a fuel line leaking right at the fuel filter (in the back, next to the fuel pump). not enough to create a puddle under the car, but enough to wet up the whole area around the fuel pump. i could smell it but not really see it. (IMG:style_emoticons/default/agree.gif) it's a disaster waiting to happen ... check all fuel lines and if in doubt *replace* (IMG:style_emoticons/default/smash.gif) Andy |
lmcchesney |
Jun 21 2004, 06:47 AM
Member Group: Members Posts: 488 Joined: 24-November 03 From: Ocala, Fl. Member No.: 1,381 Region Association: None |
Working from what can cause personal injury to what just causes displeasure.
If you have not replaced the lines, that will be the first step, because, even if they are not the cause of the fuel smell, they are still 30 years old. The PP site has a tech article on replacement. Pretty stright forward process. Most use 3/8 and 5/16 steel fuel/brake lines from your FLAPS. They run about $4 each. Drain the tank by removing the spark plug wire from your coil. Disconnect the feed line to the engine compartment and add some of your new high pressure fuel injection line(FLAPS about $1/ft) to the feed line and direct it into the gas can. Turn the key on and empty the tank. Pull tank and clean. Remove carpet and remove inspection plate at the front and rear of centeral tunnel. I pass a stiff wire through the lines in the centeral tunnel to act as a guide. Remove old lines. Bend the forward end of the new steel lines about 30-45° and pass over the guide wires into the front gas tank compartment. The rest is just plan plumbing. L. McC |
scotty |
Jun 21 2004, 11:18 AM
QUOTE The odor goes away after an hour or so, but it is fairly strong when the car it put back in the garage. Maybe a leaking injector? |
Lo-Fi Version | Time is now: 17th May 2024 - 02:44 PM |
