A bit of advise, Cruize control,visors that swivel & windshield |
ILM914 |
Jul 6 2011, 06:41 PM
Member Group: Members Posts: 96 Joined: 3-March 09 From: NC Member No.: 10,126 Region Association: None |
Hey fellow 914ers: Can anyone tell me if a 914 can be outfitted with cruize control, and if so what is the best brand and unit to purchase? Thank you. Also has anyone figured out how to rig it so one can swivel the visors away from the windshield and use the for the side windows? Thanks oh and what is the best replacement windshield to get? Thanks everyone for the help. Joe
VaccaRabite |
Jul 6 2011, 08:44 PM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
You can rig a hand throttle, but I don't know of any OTS cruise controls for the 914.
Zach |
Jul 6 2011, 11:05 PM
There are aftermarket universal cruise controls. I haven't seen one installed on a 914, but I can't think of why they wouldn't work. Might require a fair bit of fabrication, though.
There was a kit made a number of years ago to install swivel sun visors in a 914. One came on my 2.0, and we've seen pics on the board of at least one other. The middle mount is replaced by a doubled peg with a notch that the visor pivot fits into. The outer mount is replaced by a two-piece deal that is two short fat cylinders. The lower one has a hole in the side that the outboard visor pivot is pressed into. The lower cylinder rotates on the mounting screw, allowing the visor to pivot to the outside. Sorry, no pics at this point. --DD |
Mike Bellis |
Jul 6 2011, 11:13 PM
The universal units will work but you will need to add switches on both the clutch and brake pedals for safety.
ArtechnikA |
Jul 7 2011, 04:24 AM
The universal units will work but you will need to add switches on both the clutch and brake pedals for safety. I had a Dana unit that was dealer-installed on my Jetta GLI and I transferred to the ur-GTI when I transplanted the GLI engine there. That one had a vacuum servo as most do, and it was pretty painless. There are units with electric servo. Agree on the brake switch, which is easy since you're tapping an existing line. My unit did not require a clutch switch - it had a 'load-shedding / overspeed' circuit that would kill the cruise-control effect at 200-ish rpm over the setpoint. Worked fine. You could plunge the clutch or pop the shifter into neutral, see a little uptick on the tach, and it'd cut out. Used an inductive pickup over a spark plug wire (like a timing light) and sensed rpm rather than true roadspeed. No complaints. Can't have been very expensive. |
TargaToy |
Jul 7 2011, 08:16 PM
-NONSOLIS RADIOS SEDIOUIS FULMINA MITTO- Group: Members Posts: 692 Joined: 26-March 10 From: DelMarVa Peninsula Member No.: 11,509 Region Association: MidAtlantic Region |
Yes, you can add cruise control to anything. A friend of mine added an aftermarket car CC setup to his 1984 Honda Sabre.
ILM914 |
Jul 9 2011, 11:55 AM
BarberDave |
Jul 10 2011, 07:50 AM
Barberdave Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest |
Oh Crap !!!!!!!!! I finally get a post that I have 1 st. hand Experance with.. BUT , I sold it a month ago to a guy in S.C. ( Bill chime in please) along with the 914 went all the paper work about ,what brand, installation directions. I was real easy, and the Cats Ass to have, set it and forget it. It had all the safety tyhings you would expect. I mounted the switch in the hole for the rear window defroster. If I replace that 914 , I will install that 1st thing. Dave (IMG:style_emoticons/default/slap.gif) |
billh1963 |
Jul 12 2011, 12:19 PM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
(IMG:style_emoticons/default/smilie_pokal.gif) Oh Crap !!!!!!!!! I finally get a post that I have 1 st. hand Experance with.. BUT , I sold it a month ago to a guy in S.C. ( Bill chime in please) along with the 914 went all the paper work about ,what brand, installation directions. I was real easy, and the Cats Ass to have, set it and forget it. It had all the safety tyhings you would expect. I mounted the switch in the hole for the rear window defroster. If I replace that 914 , I will install that 1st thing. Dave (IMG:style_emoticons/default/slap.gif) Dave did install cruise control on his car! I have only used it once; however, it works great! I will post brand and such later tonight. |
ILM914 |
Jul 21 2011, 04:53 PM
Thanks guys any word on that cruize control brand or where i can get visor mounts that swivel? thanks, Joe
a (IMG:style_emoticons/default/smilie_pokal.gif) Oh Crap !!!!!!!!! I finally get a post that I have 1 st. hand Experance with.. BUT , I sold it a month ago to a guy in S.C. ( Bill chime in please) along with the 914 went all the paper work about ,what brand, installation directions. I was real easy, and the Cats Ass to have, set it and forget it. It had all the safety tyhings you would expect. I mounted the switch in the hole for the rear window defroster. If I replace that 914 , I will install that 1st thing. Dave (IMG:style_emoticons/default/slap.gif) |
ArtechnikA |
Jul 21 2011, 07:07 PM
ILM914 |
Jul 23 2011, 10:46 AM
Lo-Fi Version | Time is now: 17th May 2024 - 09:23 PM |
