Tuna Can, Who is the good source |
lmcchesney |
Jun 22 2004, 08:47 PM
Member Group: Members Posts: 488 Joined: 24-November 03 From: Ocala, Fl. Member No.: 1,381 Region Association: None |
I need to add a tuna can to the engine. Who is the best source? Weiltmeister?
L. McC |
Brett W |
Jun 22 2004, 09:03 PM
CAll Rich at HPH and order it. That is where I got mine for a reasonable price.
lmcchesney |
Jun 22 2004, 09:05 PM
Thanks Brett. Hope the frame strightening goes well.
L. McC |
VegasRacer |
Jun 22 2004, 10:27 PM
ELVIRA Group: Benefactors Posts: 8,507 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
Dave (IMG:style_emoticons/default/smilie_rolli_1.gif) has one listed for sale in the classifieds.
http://www.914world.com/classifieds/detail...?cat=21&de=2505 |
Brett W |
Jun 22 2004, 10:44 PM
I paid 59 shipped for mine. nuff said.
Korijo |
Jun 22 2004, 11:18 PM
[]D o [] o []V[] o []D Group: Members Posts: 1,308 Joined: 16-July 03 From: North Bend, WA Member No.: 914 |
QUOTE I paid 59 shipped for mine. nuff said. Is that new or used ? Welt. or Garretson ? Machined or not ? Just trying to get back what I paid... QUOTE I need to add a tuna can to the engine. $60 shipped. PM me... hi john (IMG:style_emoticons/default/smilie_rolli_1.gif) (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/rocking nana.gif) |
Brad Roberts |
Jun 22 2004, 11:43 PM
It took us bitchin at Weltmeister before they finally decided the TUNA they where selling had some incorrect dimensions. Not sure when they are going to implement the changes, but none of them fit in the past. I'm not even sure we have any Garretson Tuna left on the shelves. I know we have pieces...
Buy Daves. B |
fiid |
Jun 23 2004, 12:19 AM
I had to modify the weltmeister one to get it to fit. It's an easy fix with a cutoff wheel in the grinder.
Brett W |
Jun 23 2004, 02:52 AM
It was a brand new Garrettson piece. Very well made. I would definitely do it again.
machina |
Jun 23 2004, 05:27 AM
QUOTE(Brad Roberts @ Jun 23 2004, 01:43 AM) It took us bitchin at Weltmeister before they finally decided the TUNA they where selling had some incorrect dimensions. Not sure when they are going to implement the changes, but none of them fit in the past. I'm not even sure we have any Garretson Tuna left on the shelves. I know we have pieces... Buy Daves. B i just removed one from the 1.7. It never leaked. What was wrong with the tuna cans from welt? Which dims were out? also, when I removed it there was the pickup tube, the can itself, and a bushing in the tube to hold it on the pickup. Am I missing anything? Can I use a stock gasket to seal it? thanks, dr |
lmcchesney |
Jun 23 2004, 06:56 AM
I did not think the oil pickup was in the tuna can. Is that a modification? Did you eliminate the screen?
L. McC |
machina |
Jun 23 2004, 07:05 AM
I thought the pickup extension was part of the tuna can. Puts the intake for the oil lower down in the case.
And yes, my tuna can had no screen. Don't think you can use the screen with the tuna can. dr |
URY914 |
Jun 23 2004, 07:21 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,562 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Without the extension the can won't function like it needs to. The extenstion drops the pickup down into the oil.
Paul |
machina |
Jun 23 2004, 07:57 AM
QUOTE(URY914 @ Jun 23 2004, 09:21 AM) Without the extension the can won't function like it needs to. The extenstion drops the pickup down into the oil. Paul hey paul, ever have a problem with oil pressure at sebring or moroso? do you run a tuna can, accusump? thanks, dr |
URY914 |
Jun 23 2004, 08:00 AM
I've only run the Tuna Can, without any pressure problems. I worried about turn 17 at Sebring, but no problems.
Paul |
Jun 23 2004, 11:53 AM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
The problem is that they changed suppliers at one point. The new center "bolt" was too long (it actually has internal threads, so I think it's really a nut but it looks like a bolt) so you could never get the can up against the bottom of the crankcase. You can probably cut off part of the bolt, but...
We bitched at WM and they started sending us the proper parts. I think, but am not certain, that the kits with the too-long "bolts" have worked their way out of the supply chain. I don't recall the exact size of the "good" versus the "bad" ones. Pelican can get them for you, as can just about every other supplier of aftermarket Porsche parts. Almost everyone carries Weltmeister stuff. Jake hates the tuna can, but in a rear-engine'd application it seems to be a lot easier to scrape the bottom of the motor against something. (Which will trash the crankcase if it's got a tuna can on it.) --DD |
fiid |
Jun 23 2004, 12:10 PM
My problem was the pickup tube was too long. I cut about 4mm off of it and it worked fine.
You need the pickup tube because without it there is NO POINT! The idea is that when you are cornering really hard and all your oil pisses to the side of the oil pan - there is still a little oil trapped in the tuna can. The longer pickup tube is the straw through which the engine slups its milkshake (oil) from the resovoir that is trapped in the tuna can. You do lose the stock screen, and it does use the stock gaskets - although an extra copper crush washer (I think it might be the same as the drain plug) is used to seal the bottom nut (as dave said - it looks more like a bolt - has threads on the inside). When you install this thing BE VERY CAREFUL NOT TO OVERTORQUE THAT NUT/BOLT. Apparently this will cause breakage of the piece in the engine (windage tray??) which means you have to separate the case halves to repair it. |
machina |
Jun 23 2004, 12:14 PM
QUOTE(fiid @ Jun 23 2004, 02:10 PM) When you install this thing BE VERY CAREFUL NOT TO OVERTORQUE THAT NUT/BOLT. Apparently this will cause breakage of the piece in the engine (windage tray??) which means you have to separate the case halves to repair it. according to jakes video, it can actually crack the boss in the case itself. so the case would be toast. dr |
fiid |
Jun 23 2004, 12:16 PM
QUOTE(synthesisdv @ Jun 23 2004, 10:14 AM) QUOTE(fiid @ Jun 23 2004, 02:10 PM) When you install this thing BE VERY CAREFUL NOT TO OVERTORQUE THAT NUT/BOLT. Apparently this will cause breakage of the piece in the engine (windage tray??) which means you have to separate the case halves to repair it. according to jakes video, it can actually crack the boss in the case itself. so the case would be toast. dr that would be an MS BadThing. |
machina |
Jun 23 2004, 12:18 PM
QUOTE(fiid @ Jun 23 2004, 02:10 PM) The idea is that when you are cornering really hard and all your oil pisses to the side of the oil pan - there is still a little oil trapped in the tuna can. The longer pickup tube is the straw through which the engine slups its milkshake (oil) from the resovoir that is trapped in the tuna can. If the can works as you've described it, and I think it does then it is useless if you are in a big sweeping corner. The additional oil that is stored in the tuna can probably can't sustain oil pressure for more than a few seconds. This must be why most production 914 racecars have an accusump or have gone to a dry sump arrangement. Thanks for the revelation. dr |
Lo-Fi Version | Time is now: 13th May 2024 - 08:44 PM |
