air leak from tin |
air leak from tin |
ruddyboys |
Jun 23 2004, 10:59 AM
Hummel eigentümer Group: Members Posts: 594 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States |
Finally have the car running nice, but noticed I have a lot of air blowing around the right carb near the head. Its very tight between the carb and battery tray so I can't get down to see anything. I also can hear a whistle from that area. Were would the likely leak be? Is this a problem I need to go after amediately? I was thinking of putting a piece of fuel line to my ear and isolate the whistle. Is it normal to have air coming from around the tin like this, all the tin was inplace and tight when Installed the engine a few months back.
lapuwali |
Jun 23 2004, 12:18 PM
Did you seal the hole for the CHT? It's near the No. 3 plug. There are several other holes in the tin I've plugged in my car, after also feeling an engine speed "wind" blowing around the base of the carbs. CHTs (measured at the plug) even went down a tad when I did this.
TheCabinetmaker |
Jun 23 2004, 02:26 PM
The whistle could indicate a vacuum leak. possibly from the intake manifold. Make sure the bolts are tight.
Levi |
Jun 23 2004, 06:45 PM
Lick my nuts Group: Benefactors Posts: 623 Joined: 11-March 04 Member No.: 1,783 |
QUOTE(ruddyboys @ Jun 23 2004, 09:59 AM) Finally have the car running nice, Really glad to hear your car is running good. What was the problem(s) (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 13th May 2024 - 11:44 PM |
