Djet question, idle adj. screw |
Java2570 |
Jul 21 2011, 07:18 AM
Senior Member Group: Members Posts: 649 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest |
I have a 74 2.0L with stock Djet EFI and have a question Re: idle adjustment screw.
Is it normal or abnormal to hear the air slightly hissing when you increase the idle adjustment screw? It seems to become noticeably louder when I have it at about halfway out. It does seem to adjust the idle but it isn't super sensitive like I've read it should be; could I have a leak in the plenum or elsewhere? I have replaced all of my vacuum hoses and feel pretty good about them not leaking in general....however, I'm unsure about the intake plenum and throttle body gasket. I don't seem to have any real problems with high idle or idle hunting but was concerned about the idle screw hissing a bit. Thanks for the help!! |
76-914 |
Jul 21 2011, 07:48 AM
I have a 74 2.0L with stock Djet EFI and have a question Re: idle adjustment screw. Is it normal or abnormal to hear the air slightly hissing when you increase the idle adjustment screw? It seems to become noticeably louder when I have it at about halfway out. It does seem to adjust the idle but it isn't super sensitive like I've read it should be; could I have a leak in the plenum or elsewhere? I have replaced all of my vacuum hoses and feel pretty good about them not leaking in general....however, I'm unsure about the intake plenum and throttle body gasket. I don't seem to have any real problems with high idle or idle hunting but was concerned about the idle screw hissing a bit. Thanks for the help!! Normal |
kkid |
Jul 21 2011, 09:54 AM
Member Group: Members Posts: 343 Joined: 18-December 07 From: Oakland, CA Member No.: 8,483 Region Association: Northern California |
I have a 74 2.0L with stock Djet EFI and have a question Re: idle adjustment screw. Is it normal or abnormal to hear the air slightly hissing when you increase the idle adjustment screw? It seems to become noticeably louder when I have it at about halfway out. It does seem to adjust the idle but it isn't super sensitive like I've read it should be; could I have a leak in the plenum or elsewhere? I have replaced all of my vacuum hoses and feel pretty good about them not leaking in general....however, I'm unsure about the intake plenum and throttle body gasket. I don't seem to have any real problems with high idle or idle hunting but was concerned about the idle screw hissing a bit. Thanks for the help!! Normal (IMG:style_emoticons/default/agree.gif) your ears are normal (IMG:style_emoticons/default/biggrin.gif) |
Java2570 |
Jul 21 2011, 10:08 AM
I have a 74 2.0L with stock Djet EFI and have a question Re: idle adjustment screw. Is it normal or abnormal to hear the air slightly hissing when you increase the idle adjustment screw? It seems to become noticeably louder when I have it at about halfway out. It does seem to adjust the idle but it isn't super sensitive like I've read it should be; could I have a leak in the plenum or elsewhere? I have replaced all of my vacuum hoses and feel pretty good about them not leaking in general....however, I'm unsure about the intake plenum and throttle body gasket. I don't seem to have any real problems with high idle or idle hunting but was concerned about the idle screw hissing a bit. Thanks for the help!! Normal (IMG:style_emoticons/default/agree.gif) your ears are normal (IMG:style_emoticons/default/biggrin.gif) OK, thanks guys!! That makes me feel better! |
Jul 21 2011, 10:18 AM
Its an Idle Air Bypass screw.
The more its open, the more air flows past the screw. the screw is shaped like a cone, so the air will hiss going past it. rich |
Lo-Fi Version | Time is now: 17th May 2024 - 06:30 PM |
